Oxygen Sensor
08.05.2020 21:15 # 1
Ouzhan0734
I wish you a good day,
I have a Peugeot 207 1.4i petrol 2007 model car. I occasionally get an antipollution fault error on my vehicle. When I connect with the pp2000 device, I get the oxygen sensor heating control error after p0141 catalyst. Fault feature writes cc-, open loop, cc +. I wonder if only the lower oxygen sensor is defective or is it the result of another error?
08.05.2020 21:15 # 2
If there is a bad ignition, you can get this error.
08.05.2020 21:15 # 3
Ouzhan0734
I replaced the spark plugs last week. Coil was only a month. He had made an ignition error before. Now the ignition is nice, sometimes the idling cycle fluctuates very slightly.
08.05.2020 21:15 # 4
Try it, tell me, brother, take your shell-added gasoline, but use a little cycle, 4 gears like 110-130 for 10 minutes
08.05.2020 21:15 # 5
Ouzhan0734
Okay master, I will try exactly. I usually get from PO or TP. I never thought he could make it out of fuel.
08.05.2020 21:15 # 6
Ouzhan0734
[QUOTE = sonerkyl] also tell me try my brother get the shell-added gasoline, but use a little revolutions like 4 gears 110-130 like 10 minutes [/ QUOTE]
I had the old elm327 in my hand, I checked the voltage of the oxygen sensors; the upper oxygen sensor changes instantly (0.2 to 0.9) depending on the car's speed; sensor below (0.4-0.5). I have not been able to traffic yet, and I will observe in that way. I hope this is causing the error from where we bought gasoline. Or as I will deal with ...
