Oxygen Sensor
08.05.2020 15:53 # 1
vbmaster
Dear members;
Lambda Sensor, which I learned from the service box that it is a 1628HR model, has a price of 350.00 TL :) like a joke. Does this part have an impact on the excessive fuel consumption of my vehicle, or if it is defective, you will know if it is defective. Along with the coil, the lambda sensor also turned on the malfunction lamp. "Everyone says from the coil." the coil is 220 lira :) it is like a joke. Do you think that if we enter the sub-industry event, would you cripple an answer from the emergency?
08.05.2020 15:53 # 2
vbmaster
Does anyone have knowledge?
08.05.2020 15:53 # 3
vbmaster
I say lambda sensor, I say coil ... :) I say answer please :)
08.05.2020 15:53 # 4
metin
If the coil is faulty, if it does not fire, the gasoline is thrown out before it burns. The lambda sensor, which measures the fuel air mixture in the outgoing gas, is a malfunction record because there is no proper mixture. first you have to replace the coil originally.
When the coil is defective, the vehicle's traction decreases slightly, the singles do not eat gas or something. what kind of a problem you have
In addition, the original lambda sensor is bosch. If you buy from the service, you need to have 150 TL or 170 TL from the Bosch dealer.
08.05.2020 15:53 # 5
In the past, our friend came to the press, the satin name available in the forum was the same as the sea, the squeezer was out of the fuel.
08.05.2020 15:53 # 6
sahin-peugeot
I think connect it to the device, detect the error, then change it, do not try and do it, it may be in the coil, it may be in the oxygen sensor,
08.05.2020 15:53 # 7
I agree with my brother Murat, if you have the opportunity, it makes sense to connect it to the device.
08.05.2020 15:53 # 8
vbmaster
connected to device error is: coil failed then oxygen sensor error total 2 errors. Errors have been reset. I would have helped to turn the lamp on the ring road again, but after the carbon was clean, the tool was singular but it did not light. As I went and got it connected again, no futile error. I don't understand napcam. The man said, go, go, light up, don't come without burning. He said it was a shame if I did not change the piece if he did not save the error :) I said to him, look at the man.
08.05.2020 15:53 # 9
If there is a misfire, it can be from the cable of the bob. It was stuck in the vehicle once. Replace your sensor.
08.05.2020 15:53 # 10
vbmaster
my teacher, the sensor does not matter at 350 coils 220 wires, so it is 100 after it has passed :) sub-industry prices sensor 150 coils 80 wires 20 :) I have a sub-industry reputation ...
08.05.2020 15:53 # 11
sahin-peugeot
If you are going to install a sub-industry, then the sub-industry is a bit more qualified :))
08.05.2020 15:53 # 12
metin
If the lambda malfunction has gone after the carbon clean, if the carbon at the end of the carbon cleaning process has been cleaned, it has started to read more easily. If the misfire is still on, it is definitely from the coil, or the gas pump cannot send enough fuel. First, find a coil and try not lose anything.
08.05.2020 15:53 # 13
Yes, I am not a fan of you to wear you, but the decision is your teacher
08.05.2020 15:53 # 14
vbmaster
I measure human if there is a problem with the fuel pump and does this trouble cause it to burn too much?
08.05.2020 15:53 # 15
vbmaster
gncl
08.05.2020 15:53 # 16
vbmaster
08.05.2020 15:53 # 17
vbmaster
08.05.2020 15:53 # 18
metin
[QUOTE = vbmaster] I measure if there is a problem with the fuel pump and does this cause it to burn too much? [/ QUOTE]
you can't understand someone who knows should look.
08.05.2020 15:53 # 19
vbmaster
When someone says, how does the man look, does he measure the instrument or do he test drive or something?
08.05.2020 15:53 # 20
metin
[QUOTE = vbmaster] When I say someone who knows, how does the man look even, is he measuring the instrument or is he doing a test drive or something? [/ QUOTE]
look, you are lucky in this regard without konyada. There is a Ramadan master in Konya, it is said that Peugeot understands the electricity very well, and everyone who goes is satisfied. Our friends named "HRMNKY" and "kaan__" are discussing with our forum. Communicate with these friends, I believe that they will take you to the master of Ramadan, and will take care of your trouble.
Page : / 2
