overrun
08.05.2020 18:00 # 1
zknac_27
Hello friends,
I want to tell the incident that happened to me for about 2 weeks.
It gives an alarm when I reach about 120-130 km / h with my car and at higher speeds. There is an alarm called "Dık Dık" and the sound stops when I dive at 120 and below.
When the vehicle is accelerating, there is absolutely no deceleration from the moment the alr begins to come. I went up to 90km / h so I could stubbornly: D What could be the reason for this alarm?
As if there is a speed limiter, it alarms after a certain speed.
By the way my car is 2001 model 307 XT
08.05.2020 18:00 # 2
Alicilik
There is a speed warning in your vehicle. That's why you can connect pp2000e and turn it off.
08.05.2020 18:00 # 3
Serkan
My C3 has speed limit warning and it is the speed limit warning for you set to 120 km from the factory, you can have a look at the menus by using the keys next to the screen.
08.05.2020 18:00 # 4
No need to connect to the computer. Setting from the trip computer. You can find out if you browse the user manual. Good forums.
08.05.2020 18:00 # 5
Alicilik
[QUOTE = onurazgin] can we set it to 77 km / h speed, ali? do you know? [/ QUOTE]
I activated in my own car, but only 120de sound. I opened it from the screen, turned it on and off, but it did not change it. I didn't see your speed, I don't know how to adjust
My uncle had the 2006 palio and we could adjust the speed. Maybe adjustable in original systems, setting did not work when mine had a flash
08.05.2020 18:00 # 6
kuscu38
[QUOTE = Serkan] My C3 has speed limit warning and factory set to 120 km, you have speed limit warning, you can have a look at the menus by using the keys next to the screen [/ QUOTE]
Your event came directly to my dealer brother. I have a warning that can be turned off.
08.05.2020 18:00 # 7
Serkan
They put a key for switching on and off next to the tape, keeping that key pressed for 3 seconds at the speed you are going to memorize that speed and give an alarm when it reaches that speed.
08.05.2020 18:00 # 8
Erzincan406
sister can i learn how you solved the problem
08.05.2020 18:00 # 9
maximusti
[QUOTE = Erzincan406] Can I learn how you solved the brother problem
In 206+, the speed warning can only be turned on and off by connecting to a computer, but it cannot be turned off,
Mix the vehicle's menu with the trip computer keys, if there is no option such as opening and closing, it must be connected to the computer.
