overheating when ramping
08.05.2020 17:27 # 1
savasozturk
There is no problem when my vehicle is going straight. But as you climb a light or steep ramp, the temperature starts to rise. It descends down to the minimum level it can descend while descending the ramp. I wonder what. I just bought my
car. Meanwhile, the thermostat recirculation radiator has all just changed. the same problem happened before it changed, and the problem still persists. turns on the fan is no problem to turn on the fan.
08.05.2020 17:27 # 2
savasozturk
sorry my car 2000 model 206 XT gasoline ..
08.05.2020 17:27 # 3
Barut
I think there is no abnormal situation, the temperature rises a little more when the ramp is up.
08.05.2020 17:27 # 4
Only the thermostat can explain the temperature to a minimum. Look at your thermostat again, your master may be reversed, the degree of opening may be too low. Did you use the original product?
koliva 2013-03-25 06:24:38
08.05.2020 17:27 # 5
SDYMZ
I have 1.4 diesel on the ramp, it goes up to the line above 90, but the ramp does not fall down from 80 when it goes down.
08.05.2020 17:27 # 6
savasozturk
Of course, the original product was used. In fact, my master is intact, but I am seeing again. let's share the result ...
08.05.2020 17:27 # 7
okan4037
The chronic discomfort of our pejo is overheating in gasoline and it really spins out if we force it. I'm glad but I shouldn't force it on the slope
08.05.2020 17:27 # 8
samet206
It Happens In My Car, it's not a problem etcek & nothing & nbsp; Generally, it is doing on ramps for a long time, it does not do on short slopes. If you go up the ramp continuously, it increases the temperature for a while, it decreases to 70 when the slope starts to go down.
08.05.2020 17:27 # 9
by_erc
we need to take the air out of the water & nbsp; swap change savas bey & nbsp;
08.05.2020 17:27 # 10
Burak
Before my car passed 90, my fans turned on until the end was over. The temperature had improved after changing the temperature.
08.05.2020 17:27 # 11
istanbullu_3886
the fan has 2 stages according to its degree, it has to open 1st stage and 2nd stage aceba open 2nd stage
