overheating problem !!!!
08.05.2020 15:23 # 1
WallWall friends, I left the house with my car today, I traveled for 4 km, so the temperature was at 90, then the one between the two lights and the temperature of the red light went on, the stop light burned on the display, the fire went on, the car did not boil, but the car did not boil, then the water did not boil. Over 30 seconds, overheat 90 dust continued in the normal way, the service looked at the officers, he said, "If there is a problem, the vehicle will have 206 xs gasoline ..." Wall
08.05.2020 15:23 # 2
Burak07
Hope to get well soon.
08.05.2020 15:23 # 3
cesva25
get well ... if you drive the car you fight crazy, the rest will lie and shake it up :))) look at me :)) normally 600 krş yakıo with someone 800-850 krş yakıo :))
08.05.2020 15:23 # 4
Muhammet CAKIR
the problem is not in heat i think the reason for the failure of the car is redline, i think you have overloaded it :) some lpg systems cannot afford the gas Göz Kırpma I had redline, I made the redline.
08.05.2020 15:23 # 5
cerci07
can be a thermostat
08.05.2020 15:23 # 6
metin
The temperature is high, but when you open the hood, you say that the water did not boil, maybe the temperature sensor shows more than it is broken.
08.05.2020 15:23 # 7
motoberk
It happened to me today though a slightly different situation than yours.
When the road was normal, the temperature rose suddenly. I said I looked at the water 2 hours ago, I said it looked like there was water because the master made air, I think it's related to pressure. The heat did not increase until we went to industry, but we did not burn the gasket.
The problem is that the circulation pump has been replaced. No water was coming into the engine, both the hoses were clogged and filled the pump shaft.
08.05.2020 15:23 # 8
I think the thermostat may have malfunctioned. If you want a show.
08.05.2020 15:23 # 9
friends common blood thermostat i guess i look at it tomorrow i wear the new one should not be expensive :))
08.05.2020 15:23 # 10
Around 60-70tl. of course, first look maybe not faulty.
08.05.2020 15:23 # 11
They looked at it today, the musurlar was strong, the master could not open the thermostat.
