overheating problem 206
08.05.2020 16:56 # 1
soldiermertefe
friends, like all peugeot, in my car the heat & nbsp; had a problem, the temperature came to 90
suddenly was rising rapidly, no matter how much I went to the master, I couldn't find a solution, finally I darkened my eyes and cleaned it with radiators, expansion vessel & nbsp; I said let me look at the fine drain pipe between the expansion vessel and I saw that the pipe was clogged, I opened the pipe with pressurized water & nbsp;. When it is clogged, the cooling system compresses itself and the temperature of the vehicle rises suddenly, just like a broken thermostat.
08.05.2020 16:56 # 2
toga406
you are great my friend thank you
08.05.2020 16:56 # 3
Thanks. An experience that needs to be recorded.
08.05.2020 16:56 # 4
soldiermertefe
Let me give a little more information & nbsp ;;
- if the fan is running, the thermostat is 90% solid,
- if the radiator is blocked, even when the ramp is going down & nbsp; idle & nbsp; or not in gear & nbsp; overheat 90 gold is hard to see,
- summer winter anti-freeze vehicle for healthier (such as corrosion, late heat early cooling),
- use with summer winter thermostat & nbsp; engine & nbsp; is crucial for fuel consumption and wear.
08.05.2020 16:56 # 5
secur73
My friend would find 100 in my car's temperature. No matter how hard I pushed for the last week, it doesn't go over 90. There was a stuffy place.
08.05.2020 16:56 # 6
MagicPerformance
friends pug group runs hot 100s there is no situation to worry about the normal values for our vehicles.
08.05.2020 16:56 # 7
pug206
my car does not turn on the first stage fan.
08.05.2020 16:57 # 8
soldiermertefe
first stage fan & nbsp; you will hear it hard anyway, but you can even hear the second stage fan on the go.
08.05.2020 16:57 # 9
sezar206
There is Elmadağ between my car the other day Kırıkkale Ankara (who knows) and the car is loaded as it climbs in the heat of the day. The temptation endured up to the last white line, outside it was 42 degrees. But it does not exceed 100 other than that. do not be afraid, so there is no problem until the last line. As I climbed that hill, how many cars had overheated and pulled over.
