overheating does not get rid of red light
08.05.2020 17:47 # 1
hk26
I changed all of the mugs, a circulation pump is left. If I change it, the problem will be solved. I am waiting for help.
08.05.2020 17:47 # 2
semus
If the radiator is dirty, it can make a room.
08.05.2020 17:47 # 3
ErolSs
I think the car is really overheating
08.05.2020 17:47 # 4
samet206
I changed the circulation when changing the triger, the temperature does not exceed 80, the periods are not in the winter, but do not misunderstand, only when the ramps are coming up, it feels a little towards 90.When considering the result, I think that the change in the recirculation will be effective, the vehicle does not really make the car alone, as it says, does the car really show up. there is room ?
08.05.2020 17:47 # 5
Burak
If your temperature is rising, well, just my lamp is on, check the oil of my car.
08.05.2020 17:47 # 6
hk26
Ewet engine stopper engine engine faded heat transmission circulation pump changed again, the last time I had the faulty officer, summer 78-62 this time the fan worked harder but reduced the heat fan coo running after ten minutes, the fan turned off after ten minutes, no man in the circulation pump My black car is almost short, my first car and a lot of sewiorum, or I will burn it with gasoline
08.05.2020 17:47 # 7
hk26
hk26 2013-07-16 02:10:33
