overheating
08.05.2020 14:16 # 1
fieryx
slm good forums
friends 2004 1.4 gasoline 206 xt user I am looking at the overheat gauge of the car's engine hood over 90 is 80, but the hood is almost like it will not burn, I am afraid that this will cause a problem in the future.
08.05.2020 14:16 # 2
The heat of the engine itself and the extreme temperatures started to come, can it be caused by the sun's heat .. or is there a problem with the fan?
08.05.2020 14:16 # 3
seLim
it cools the engine but the hood is hot;) I don't think it can get chronically in the 206's
08.05.2020 14:16 # 4
Long Beach
Is there any insulation on the bonnet?
Also, since the motor temperature is normal (fan is running)
If it feels uncomfortable (if not present, on the inside of the bonnet), insulate.
And
Don't forget to read the article below Göz Kırpma
08.05.2020 14:16 # 5
deniz_206
Yes, I have the same problem with me.
08.05.2020 14:16 # 6
Long Beach
The same problem (isolation)
In order to keep the cost down, they may not do it in some models (all manufacturers).
08.05.2020 14:16 # 7
fieryx
Thank you for the comments, I was out of the province, I came today, I am sorry, I can read more ...
08.05.2020 14:16 # 8
Sonmez
I can make a hot ceiling too =)
08.05.2020 14:16 # 9
TheEchoes
If the egg is cooked on the hood, the situation is bad :)
08.05.2020 14:16 # 10
Long Beach
If the motor is not overheating and the fan is running properly, the rest is psychological.
If it bothers you and does not have it, isolate it.
In the brake, if you see the linings and discs, then the brake system
you try to have an air conditioner installed. Sırıtma
Look what it says below Göz Kırpma
08.05.2020 14:16 # 11
ozaannn
friends, do you remember me? Is there any problem in the act? I have solved my problem. Replace it. 85 TL.
08.05.2020 14:16 # 12
clbyusuf1
I have the same problem in me, but I do not have internal isolation in the hood, it was previously removed.
25.07.2024 01:09 # 13
Umitsri
When you say circulation pump, which part exactly is it? My car is 1.4 HDI.
