overheating?
08.05.2020 18:38 # 1
error
Hello friends after a long time, an interesting situation I could not solve, so I said to be a consultant,
The temperature indicator has not been able to reach 90 as before, it stays around 70, there is no water reduction.
10 15 km I came, did not exceed 70 in this heat, does the indicator point to this circulation pump problem?
08.05.2020 18:38 # 2
Barut
The thermostat remained open Replace the thermostat will recover.
08.05.2020 18:38 # 3
error
thank you let me check the red pipe temperatures from the engine to the radiator .. error 2014-06-23 18:25:25
08.05.2020 18:38 # 4
droprain72
my friend err
My vehicle is diesel and it does not exceed 70. However, it passes 90 in the traffic jam and turns on the fan. I asked the master, he said normal.
08.05.2020 18:38 # 5
t.alp
the situation is not the norm, the thermostat is open, until the thermostat value reaches, there must be circulation in the block. cold running will reduce engine efficiency
08.05.2020 18:38 # 6
error
Talp is absolutely right, whatever the temperature outside the summer and winter should be, the temperature should be 80 90. 90% of your thermostat is missing a check.
By the way, I did not find the problem in me yet. The indicator remained at 70 again. I made the contact on and off. At this time, the thermostat indicator came to a point below zero at the bottom of the zero.
08.05.2020 18:38 # 7
error
Friends, there is improvement, I follow the temperature from OBD, but sometimes the indicator of the vehicle shows correctly, sometimes it drops below zero. I manage but do you think the problem is indicator gear or should I 100% trust the temperature in OBD?
08.05.2020 18:38 # 8
suppor
The same problem exists in me. I see 90 very rarely.
But if the masters do not overheat, they will work better and perform better.
but they said a lot of money, they haven't come to him yet
08.05.2020 18:38 # 9
error
friends led the license plate lights, I turned them into normal lamps, the indicator has improved. It is strange.
