overheating
08.05.2020 18:12 # 1
droprain72
Hello friends
I have read many topics on temperature in this forum before, but I have not seen a subject about my complaint.
diesel 2005 1.6 HDI 110 ps sw. I have a car. It has been 3 months since I bought my car. I don't know if it is cold anymore but 300 km. I went on the road and the temperature indicator remained between 70-80.
My question is: I wonder if I have a low-temperature thermostat or another problem, I have never seen 90 degrees.
respects...
08.05.2020 18:12 # 2
kivanc
My 206 vehicle was always 80 on the long road, my friend had sw 206 I always have 80. I think there is no problem. It gets higher when you squeeze a little in the summer.
08.05.2020 18:12 # 3
droprain72
They say that if the temperature does not reach 90 degrees and the engine does not reach the full temperature, it will affect the fuel.
08.05.2020 18:12 # 4
kivanc
As I said, I have used it for many years and I know 80 is normal. I was easily passing 1000 km to a warehouse. I had no trouble with fuel. it burns when the engine is cold and the wear is high but I know 80 is normal
08.05.2020 18:12 # 5
tellotello
It has been 3 months since I bought the car, what was the situation 3 months ago? How was your vehicle acting when the weather was not so hot? Does he ever see 90 in congested traffic, not on the long road? If you answer them, friends will be able to help you more easily.
08.05.2020 18:12 # 6
Bugra
it is normal to be at 80 because the vehicle runs comfortably on the long road But if you stop and get up and down in congested traffic in the city and the temperature is not 90a and the fan is not turned on, it is a problem.
08.05.2020 18:12 # 7
kivanc
[QUOTE = tellotello] It's been 3 months since I bought the car, what was the situation 3 months ago? How was your vehicle acting when the weather was not so hot? Does he ever see 90 in congested traffic, not on the long road? If you answer them, friends will be able to help you more easily. [/ QUOTE]
Stop, he must get up, yes, but my friend said I went 300 km long road, and I said 70-80 normal from there. the bidet is cold. We haven't seen any hot in 3 months :)
08.05.2020 18:12 # 8
droprain72
There is the same problem in the city, but there are the same problems in the city. It is up to 80.
08.05.2020 18:12 # 9
kivanc
My fan opens the fan at 100 degrees
08.05.2020 18:12 # 10
Bugra
Well, to find out if you have any problems with your own diameter, use the vehicle cycle and try bidet death. so do things that will increase the vehicle's temperature. While stopping, press the gas at 3 thousand 5 thousand revolutions in empty gear. Let's see how many degrees the fan will turn on the car.
08.05.2020 18:12 # 11
korkusuz202
I do not know the temperature is over 70, 75 does not exceed.
08.05.2020 18:12 # 12
droprain72
Buğra brother, I think there is no problem in my own diameter. I have a license for 29 years and this is my 4th pejom. I had 2 206 before, this was my 307 vehicle. And all of them were diesel. I was seeing the heat in my other pejoes in 90-100s.
I have destroyed 300 km and my average speed is 100 km. the average fuel is 5.3 liters. I think the engine burns too much because it doesn't reach its full temperature.
08.05.2020 18:12 # 13
Bugra
brother now changes according to the vehicle then the temperature indicator or value. If there is a friend in the forum which is the same version as your vehicle, then we can reach a clear information. I think you can change the title, like, `` Have a look at those who use 307. '' then maybe we can get comments from other user friends. I looked at me from work now so I didn't see 90 fever
08.05.2020 18:12 # 14
kivanc
[QUOTE = Buğra] brother is now changing according to the vehicle then the temperature indicator or value. If there is a friend in the forum which is the same version as your vehicle, then we can reach a clear information. I think you can change the title, like, `` Have a look at those who use 307. '' then maybe we can get comments from other user friends. I looked at it now when I was leaving from work, so 90 did not see the temperature [/ QUOTE]
I realized after your post, I thought the tool was 206. I am using 308 right now.
08.05.2020 18:12 # 15
kursat3006
I think there is no problem from the cold. My 80 does not exceed. The subject of fuel is very close to the vehicle before 70 and the optimal value is 80.
08.05.2020 18:12 # 16
bozkurtum
I have 307 1.6 hdi 110 horsepower. 2006 model. I have been using it for 2 years ... The temperature is between 75-80. It turns out to be 90 in normal. So there is no problem. It is in the 75-80s when the weather is cold. There is no problem bro. I live in the 90s in summer but now there is no low problem ..
08.05.2020 18:12 # 17
kuscu38
[QUOTE = droprain72] Hello friends
respects...
the same problem has been in me for two weeks. The thermostat stays open all the time !!!
08.05.2020 18:12 # 18
kuscu38
[QUOTE = droprain72] say that the temperature will not affect 90 degrees and that the engine will not reach full temperature, it will affect the fuel.
I do not know if the temperature is not harmful for the fuel, lpg ci said the fuel will increase because of it and it is right but the temperature is too high for the engine is good for the life of the engine :)
08.05.2020 18:12 # 19
kursat611
in the summer, on highway 75, if I compress the city 80 - 85, I even saw 100. Now if I force 70 in the city 80
I think it should be airborne compared to the normal summer, and when I entered the winter, I put a red antifreeze 3 kilos - it was measured 30 - antifreeze may not be heating up.
my car 1020 pound engine 110 horsepower may not be warming up since it has no difficulty in normal use
08.05.2020 18:12 # 20
[QUOTE = Buğra] It is normal to be at 80 because the vehicle runs comfortably while on the long road. but if you are doing low-speed stop-and-go traffic in congested traffic in the city and the temperature does not rise to 90a and the fan does not open. [/ QUOTE]
just like it can be accepted in 95. It is between 80-85 on the long road and generally 80-2500 rpm on straight driving.
Page : / 2
