overheating
08.05.2020 17:52 # 1
oguzhan53
when my friends go on the road with my vehicle, the temperature jumped to 130, when I was on the road between 85-90, wrote stop, immediately stopped, opened the hood, the fan was not working, I immediately turned on the air conditioner, the fan employee fell suddenly fell to 90, when I arrived home on the road carefully, when I tried to give the car gas and try the car 3 times everything turned out to be normal, so why does the temperature rise and fall and the fan does not turn on. oguzhan53 2013-08-13 20:57:06
08.05.2020 17:52 # 2
sebebsiztayfa
If the thermostat is faulty, when the thermostat reaches a certain degree, the fan turns on and if the fan is intact, the thermostat is faulty.
08.05.2020 17:52 # 3
ertanakar
Fan roll, open the hood, there is a cell phone-sized cover behind the black blind in front of the radiator. they asked me for 1100 lira for this breakdown, I made it 40 lira. The role of the electrician was broken by the second hand. It exploded in 10 liras. The heat was coming to 95, the fan was turning on but the pointer lasted until the end and the stop light was on ... the water continued from where it left off.
08.05.2020 17:52 # 4
vbmaster
[QUOTE = ertanakar] fan role, open the hood, there is a cell phone-sized cover behind the black blind in front of the radiator, open it. they asked me for 1100 lira for this breakdown, I made it 40 lira. The role of the electrician was broken by the second hand. It exploded to 10 liras. The heat was coming to 95, the fan was turning on but the pointer lasted until the end, and the stop light was on ... the water continued from where it left off. / quote]
teacher, you explained super 10 lira to 1100 where do you think I should follow this path, let our friends have our mind ...
08.05.2020 17:52 # 5
ertanakar
classic pejo problems, what happened to us ... they couldn't help us .. i am looking for prayer .. Cool
08.05.2020 17:52 # 6
vbmaster
is true ...
08.05.2020 17:52 # 7
oguzhan53
if the box with thick cables in front of the radiator enters, can the fan actuator be reached without removing the bumper?
