Overheating
08.05.2020 20:58 # 1
yfk
When I use my car pejo 206 ralond garos package, when I use the car, the temperature without air conditioner reaches around 100-110 when the air conditioner is turned on and when the contact is turned off, the fan works very long whatever the temperature is.
Fan operation with ignition off: https://youtu.be/p8bIuz2x9IU
Yfke 2018-07-29 13:40:25
08.05.2020 20:58 # 2
Selcuk55
If the temperature is up to 110, it is not important whether the fan runs in the range of 90_110, including normal strings, it doesn't matter if it stops after a while.
08.05.2020 20:58 # 3
yfk
The fan shuts down after running the fan after a long time but it shuts down after running a bit longer
08.05.2020 20:58 # 4
Selcuk55
When it stops normally, the vehicle cools the water in the radiator so that it gives cold water when it starts
08.05.2020 20:58 # 5
aykutbayram1996
friends, my car is reading abnormal glb forum always 100 110 my car is 90 if you force it too hard 93 it falls back immediately fan double stage only hurts when the air conditioner turns off, there is a thermostat which is not always on.
08.05.2020 20:58 # 6
Selcuk55
If your temper has changed, the side industry has changed, the fan is opening early.
08.05.2020 20:58 # 7
boruc
I have roland garros at 110
When the air conditioner turns on, the temperature drops because the fan is activated.
I even open up the air conditioner when it stays in traffic, so that the fan stays on continuously so that the temperature does not rise.
08.05.2020 20:58 # 8
aykutbayram1996
No, it hurts a little after 90 nights, it stops right away.
