Overheated ceiling
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 21:15 # 1
Duha
Hello to everyone
I am writing from Mongolia, there is no peugeot service to get your information from it. As soon as I start my car early in the morning, the temperature is rising and the cooling fan is running non-stop. Then the engine Engine check is on. Peugeot 208 model 2013. Some call it an electrical problem, some call it a pump, some call it a thermostat. I am waiting for your answers. By the way, I wrote with English keyboard since there is no Turkish keyboard. Best regards
08.05.2020 21:15 # 2
umydn
[QUOTE = Duha] Hello Everyone
Does the temperature decrease when the cooling fan turns on after the heat? Does the fan stop after overheating?
08.05.2020 21:15 # 3
Duha
When the switch is pushed once, the temperature rises directly to the ceiling, and the cooler fan starts after the engine starts, but the temperature does not decrease. The light called Stop is on. when the car turns off, the cooler fan runs without stopping, I remove the surplus from the battery and stop it. I can't send a picture. There is no Peugeot car service here, I'm suffering from it. I would appreciate if you help
08.05.2020 21:15 # 4
ismailkaya
change the customer first, the customer may have electrical leakage in the cable or the customer may have the ceiling in the room, then the fan may be activated. There might be water in your hose. There may be no water in the radiator. Check
