Overheated
08.05.2020 18:06 # 1
MertMurat
My car overheated today, 100 output indicators and 3 times (Beep Beep Beep) (Beep Beep Beep) (Beep Beep Beep) sound was not the one that gave when the gas was low. You know, there is a sound that comes out when the gas is running low, but why is this sound coming out?
When it came to the heat, I filled with water in the place where I bought gas yesterday night, but the normal water level had fallen down, it was at the bottom where it was written. now I will take antifreeze water and fill it, how can I drain the water inside
mertmurat 2013-11-30 13:35:55
08.05.2020 18:06 # 2
mev347
you can evacuate the pipes going to the radiator, but the vehicle is first download?
08.05.2020 18:06 # 3
206FR
Generally, there is a drain plug under the radiators and you can empty it from there.
08.05.2020 18:06 # 4
kursat3006
If you put the water too much and if the engine is hot and the cover is on, the radiator has also made air, don't put the antifreeze by yourself.
08.05.2020 18:06 # 5
cansytnn
I can tell the incident that happened to me. I did the heat in March and there are roads up to 0 engines.
08.05.2020 18:06 # 6
MertMurat
My vehicle 307 xt 1.6 gas + gas
