over temperature 80?
08.05.2020 18:00 # 1
error
Hi friends, I don't mind much for a long time. When the vehicle moves and starts to take the wind, the temperature falls to 80 and stays there. or why?
thanks...
307 2.0 gasoline
08.05.2020 18:00 # 2
Mesut48
I noticed the same in my 206, I was 90 in summer, now I follow 80 answers :)
08.05.2020 18:00 # 3
error
it is probably not harmful, but I wondered if it could be a sign of a malfunction.
08.05.2020 18:00 # 4
qqyyxx
No problem, everything is doing well in the thermostat on the fan.
08.05.2020 18:00 # 5
samet206
I have used my car today, do you believe that the 206 is not stuck in my head, I wasn't alone, the temperature in the 90s did not exceed 80, but the temperature is not open in the fan, but the temperature is not 80, I do not know what it means, but this is the first time this is the case, the temperature is high, the reason is that the reason is not in the shower. If you have any information, I am a team :)
08.05.2020 18:00 # 6
berk2309
When we take the natural wind, when it stops, it travels over 90 in the 307s :)
08.05.2020 18:00 # 7
samet206
[QUOTE = berk2309] When we take the natural wind, when we think of it, it travels over 90 in the 307s :) [/ QUOTE]
I agree, I can agree with him, my teacher because it happened on a long road, and the event I said was frozen when he got into the city traffic.
08.05.2020 18:00 # 8
berk2309
Honestly, my teacher, I did not reach 90 nights, I did not change, but I did not change it, but they bole: Boil: When the wind gets D, the ceiling goes off when it stops: D
08.05.2020 18:00 # 9
[QUOTE = qqyyxx] no problem everything is doing its job very well in the thermostat on the fan. [/ QUOTE]
exactly Smile
08.05.2020 18:00 # 10
cyberturk
Friends, the temperature indicator sometimes doesn't get up at all. when I stop the car and start it again it shows 80 90 what is the reason? My 307 XT vehicle.
Best regards.
08.05.2020 18:00 # 11
Furkan ONEY
Good evening guys. The temperature should be 80-90 and the vehicles open as many as 88-90 fans.
08.05.2020 18:00 # 12
fth306
I get over 90 in very hot weather, it drops when the fan is running (if I am in traffic) it changes between 90-80 in the hot weather on the long road, 80 is from normal wind if the weather is cold.
08.05.2020 18:00 # 13
eren106
If the values are normal but antifreeze is not necessary, thermostats will cause rusting because the circulation pump is in the water. Then your head hurts.
08.05.2020 18:00 # 14
kuscu38
GAME TO BE 80 NORMAL. IF IT DOES NOT EVEN IF IT IS DIFFICULT, IT MAY ALSO BE THE INDICATOR OF THE FAILURE ... DOES IT REMOVE A RADIATOR WATER IN 2-3 DAYS?
08.05.2020 18:00 # 15
error
There is no shortage bird, also I can not press the vehicle 2000 engine, because of gasoline prices 2500 I use it around 2700 rpm, I think the engine may not be overheating.
already exceeds 3000 rpm 90 a aligns thermostats, in durkalk 90 95 steadies already giving me a window open hand to open the heating habits: D
08.05.2020 18:00 # 16
kuscu38
Then I think that it will not be a problem for me.
08.05.2020 18:00 # 17
On the long road, it is 80 normal, stop and stop 90, even 95 normal, but 95 fans need to open If it doesn't hurt and it rises to 100, trouble
