Over 90 temperature
08.05.2020 15:23 # 1
berk2309
friends, I changed the thermostat in the summer, I changed the circulation pump with the triger set 1 month ago, but the temperature is still 90% above the line but overnight
08.05.2020 15:23 # 2
metin
wow friend I got a question about the 3rd thermostat in 1 hour (:
has it been since the thermostat has changed or has it been since the timing changed?
08.05.2020 15:23 # 3
berk2309
I changed the thermostat, it remained the same, the output of over 90 remained the same after I changed the circulation
08.05.2020 15:23 # 4
metin
So first of all, there is a blessing from summer. Actually, 95-100 is normal, but I know that the weather was cold for a long time, I do not think that it will rise this much in cold weather.
08.05.2020 15:23 # 5
berk2309
When I open the air conditioner, the fan is running in 89 88, and I am in Cyprus.
08.05.2020 15:23 # 6
metin
It is normal that the temperature is in the 95-100s. The knock job is not heated too, but because the oil inside the gearbox gets too hot and then loses its feature when it gets hot, it becomes knocked on the transition due to the lack of pressure in the gear shift. Firstly, if there is no oil change (oil change is very important, it is necessary to put the right oil and the right level, more or less), the problem is solved with solenoid valve change.
08.05.2020 15:23 # 7
berk2309
thanks bro you thank you for your help
08.05.2020 15:23 # 8
mdincer34
It is happening in me, especially when I stay in traffic, my eyes always exceed 90 in the hand, and if I go to the red area, I will stop immediately.
08.05.2020 15:23 # 9
berk2309
In my mind, when the dusuo stopped while going to the ole, I jumped over 90 immediately
08.05.2020 15:23 # 10
It is normal.
