Osram H7 Hyper White 5000K
08.05.2020 16:56 # 1
yenice
Hello.
http://www.hepsiburada.com/liste/osram-h7-hyper-white-5000k-2-li-ampul-seti-90c62210cbh/productdetails.aspx?productıd=otm90c62210cbh&categoryıd= 20024642 & amp; SKU = OTM90C62210CBH
& nbsp; I plan to wear both short and long. Does anyone use this product and is the visibility better or worse than normal headlights?
Does it cause trouble in rainy weather? If there are friends who use it, I would be glad if they give information. Thank you. Reviews
08.05.2020 16:56 # 2
SZKR
I also need a headlight bulb recommendation, I follow the subject .. SZKR 2012-07-28 00:21:25
08.05.2020 16:56 # 3
Alicilik
Osram & nbsp; Although he has been working on this business for years, Philips got the number 1 from OSR.
Osram's quality is still very good. The prices are also reasonable, but Philips cannot perform as much as the vision series.
I searched for the high-end bulb of Osram, often suggested a night breaker for osram. But Philips' 2-3 higher level bulb is available on the market, with X-treme, diamond and ultimate taking the lead. If there is a financial opportunity, I recommend using x-treme. The value of Kelvin is very suitable and it is very good in terms of road visibility, long-term use, and its reflection on the opposite side. The closer the brightness increases as the Kelvin value increases. However, this brightness reduces the reflection in the distance and causes unnecessary light rays to the eye unnecessarily. This, in turn, can cause problems like burning eyes, temporary blindness on long roads.
08.05.2020 16:56 # 4
yenice
I think these ampoules give the X-treme diamond and ultimate yellow light.
The white light I want to wear. I don't want to get into xenon business. I will attach 4 white bulbs to the short and long.
but I want to get information from friends who use the brand and performance. Thank you. Reviews
08.05.2020 16:56 # 5
Alicilik
diamond vision is 5000K. There is blue vision, which gives a brightness between 6000-7000.
Are you looking for performance but how often do you use your car? If you use the city in a short distance, bluevision is what you want. But if you use your long way and think about your eye health, do not go over 5000K. Reviews
08.05.2020 16:56 # 6
yenice
So is H7 Diamond Vision 5000K or Osram H7 Hyper White 5000K?
There are comments like Osram exploding quickly. & Nbsp; But there are also comments that light clarity and quality are better than osram.
No positive or negative articles have been written about Phlilips.
08.05.2020 16:56 # 7
carantinas
Well, friends, I asked Opel in the past, they are making Philips xenon applications. Starting from 700 800 TL xenon applications Philips seems to have done the job in almost all places .. & nbsp;
08.05.2020 16:56 # 8
jiyanxese
mrb friends get me osram or philips performance bulbs for a better view for my car & nbsp; I want but I don't know these H values. How many numbers should I buy? Should I buy separately for short and long. Do I have problems in traffic inspection. Is there a brand or series you recommend for a better road view?
08.05.2020 16:56 # 9
jiyanxese
actual
08.05.2020 16:56 # 10
voodoo
osram is more qualified about light bulb and lamp, i think die ......
08.05.2020 16:56 # 11
yenice
[QUOTE = jiyanxese] mrb friends to get osram or philips performance bulbs for a better view for my car & nbsp; I want but I don't know these H values. How many numbers should I buy? Should I buy separately for short and long. Do I have problems in traffic inspection. Is there a brand or series you recommend for a better road view? [/ QUOTE]
This H value is related to which model bulb the vehicle is using. for example, short and long light bulbs are H7 for 206.
http://www.hepsiburada.com/liste/osram-h7-hyper-white-5000k-2-li-ampul-seti-90c62210cbh/productDetails. aspx? productId = otm90c62210cbh & amp; categoryId = 20024642 & amp; SKU = OTM90C62210CBH
I bought this amp and inserted it shortly. There is Philips in the long.
First, I was going to wear osram h7 hyper white 5000k for both short and long but I wanted to try it shortly first. If I wear it for long, I saw that when it goes to asphalt, the image will be zero. I'm having a lot of difficulties with the shorts right now.
08.05.2020 16:56 # 12
jiyanxese
So what is dipped beam and main beam in 307 (h1 h7)
