Original Tape with Mp3 Player
08.05.2020 19:06 # 1
Mikalgabirtae
Is there an original tape that plays mp3 to the 206+ Plus car? a tape where I can see the name of the parts that play compatible with the trip computer compatible arm
08.05.2020 19:06 # 2
monalos
There is no tape like that but there is an apparatus called aux changer you plug it into the cd changer socket of the tape
You can also use usb-sd-aux 3 function. steering control active, active on the screen but not writing music names on screen, typing names cd1-cd2
I did not use: these are the things I hear from those who use D, but I will take the beautiful side, I hope
08.05.2020 19:06 # 3
Efe-Pojo
[QUOTE = Mikalgabirtae] Is there an original tape that plays mp3 to the 206+ Plus car? a tape where I can see the name of the parts that play compatible with the trip computer compatible arm [/ QUOTE]
There is the same as the normal tape in 207 but there is only the mp3 phrase on the cd input. of course I assume this is not the usb mp3 you call. You can play cd mp3 in this way and the information screen will be the model with graphic display and the track names can also be displayed in a list. The 207 and 206 plus are largely similar to the dashboard, so it is likely to be in your vehicle.
08.05.2020 19:06 # 4
Alicilik
206 and 206+ vehicles operate on a simpler built van line. The tape is directly connected to the brain in a simple structure.
The situation is very different in 207. The tape has a different structure and there is also a life line in the vehicle. It is more complicated and advanced by looking at the valve.
Plays 207 tapes of MP3 CD. Some models support USB and AUX, and there are models that support original Bluetooth with an additional apparatus.
For the compatibility of 206+ and 207 tapes, it is necessary to think a bit and experiment. There is a socket difference at the very beginning. You have to learn the outputs of the socket and try the same output with the Fakra-ISO converter. Of course, the number of the vehicle is recorded on the tape of the Pejos. When the tape is opened, it checks its volume number with BSi. If the result is equal, the tape will work normally, but if it comes out differently, the tape will not run or sound.
I used top serial pioneer tape in my 206+ vehicle. I activated the joystick. Not only does the information go to the screen, but I didn't care much about it.
08.05.2020 19:06 # 5
gakkos43
What brand is Clarion? blaupunkt?
08.05.2020 19:06 # 6
Efe-Pojo
[QUOTE = Buyer] 206 and 206+ vehicles run on simpler built van lines. The tape is directly connected to the brain in a simple structure.
you are very dominant in the brains of peugeot, this is clear Can we actively leave the original tape of the vehicle I want to ask and attach an additional tape to the space below?
08.05.2020 19:06 # 7
Alicilik
[QUOTE = Ef A-pojo]
I don't understand what exactly you want to do?
To operate an external tape, only 3 connections are required and the rest is for speakers.
+ 12v memory supply
+ 12v contact supply
- Sase.
It is enough to get them from the socket of the original tape.
08.05.2020 19:06 # 8
Efe-Pojo
[QUOTE = Acquisition] [QUOTE = Ef A-pojo]
+ 12v memory supply
- Sase.
I want to continue to use the car without operating the original tape, but instead of the empty eye under the tape in the chest, I want to insert it from the tape reading sd card. Is this possible?
08.05.2020 19:06 # 9
monalos
Efe-pejo; it is possible, but it is possible as follows,
You attach the tape to the lower part, remove the speaker socket from the back of the original tape and attach it to the lower tape.
From the top of the tape + End to a Feed, in Memory + Take it and then - When you make the connection, your bottom tape will work in your top tape, not just the top one.
I can suggest you something like aux changer devices around 170 TL aux-sd-usb are all working. Since the device is small, you can put it anywhere you want. The steering wheel continues to work.
08.05.2020 19:06 # 10
Efe-Pojo
[QUOTE = monalos] Efe-pejo; it is possible, but it is possible as follows,
:) If it doesn't sound out of the top when you say this, doesn't it mean it's not working anyway? I understand that I would remove the socket of the original tape and plug it into the other tape, but leave it in place without disassembling it, so that the tape will only light up when the headlights turn on, but the sound can only come from the tape that was attached later? if not then this is not what I want, of course, I am asking how we can make a separate connection and introduce it to the brain without passivating its original.
08.05.2020 19:06 # 11
monalos
I let you keep the original tape, but let me put the tape down at the bottom, let me insert the sd card and listen to the music.
I want you to put the tape at the bottom of your request.
08.05.2020 19:06 # 12
Efe-Pojo
[QUOTE = monalos] I let you keep the original tape, but let me put the tape down at the bottom, let me insert the sd card and listen to the music.
No, I want both to work separately, it's that simple. I do not want to control the radio afterwards with the original remote. but as far as I understand, the job is a bit complicated, because I haven't met anyone who is using it originally or the original tape is removed and another tape is attached.
08.05.2020 19:06 # 13
monalos
: D I understand your request now You were not so descriptive in your above messages.
I think it's possible to do what you say;
As I have described, plug your tape to the bottom, connect the feeds, then when it comes to the speaker socket, you will make it parallel to the upper tape, but you need to put diodes together because when the upper tape is turned on, the voltage will go to the speakers, and that voltage will also damage the outputs of the tape below. The same goes for the above.
With a little thought, your problem is solved with a small electronic circuit. It is not done, it is not done. Let me give you some research.
08.05.2020 19:06 # 14
monalos
I drew a diagram like this, when you apply this wiring diagram to the + output of each speaker output, you get what you want.
A total of 8 diodes, which will be 8 + output, means something between 1-1.5 TL, so it does not require cost.
If you say you want something more professional, I will draw an electronic printed circuit.
08.05.2020 19:06 # 15
Alicilik
Working both takes a bit of effort, but there may be water,
You take the new tape and make the speaker connection to it. The eclectric connection remains on the old tape, as I mentioned above, you only get the electrical connection.
08.05.2020 19:06 # 16
Efe-Pojo
anyway, it is very complicated, thanks to both of you, patience is still the best solution.
08.05.2020 19:06 # 17
sanctuary35
So, can the 2006 model 307 and 207 tapes with mp3 players be attached?
In my car, I have a tape with a round audio on and off cd player. The front and the back outlets look the same as my tape, the only difference is that one plays track cd and one plays mp3. If it works, I'm thinking of getting 207 tapes from the service.
08.05.2020 19:06 # 18
Efe-Pojo
[QUOTE = sanctuary35] so can 2006 model 307 or 207 tapes with mp3 player be attached?
[/ QUOTE] I think my teacher won't give a tape of 400 lira. 400 pounds of great brand tape plus trinkets I think a lot of other things are taken.
08.05.2020 19:06 # 19
Alicilik
If I find a tape, I will try and no tape
08.05.2020 19:06 # 20
sanctuary35
[QUOTE = Efe-Pöjo] [QUOTE = sanctuary35] so can 2006 model 307 or 207 tapes with mp3 player be attached?
[/ QUOTE] I think my teacher won't give a tape of 400 lira. 400 pounds of great brand tape plus many other stuff, I think it will be taken. [/ QUOTE]
I do not want to spoil the original 13 I will be cracked by listening to the song. there is no other option that can work. they want around 200 used
Page : / 2
