Original stop construction with 307 LEDs
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 16:59 # 1
fexzi
Project Name: Peugeot 307 led mounting to original stops Project Producer: Fexzi Car Brand: 2004 Peugeot 307 Project Location: Exterior-Stop Material Used: Narrow angle as much as needed, orange led, 100 ohm resistance, voltage stabilizer integrated, dremel, animal, solder for cutting mowing process , necessary cables and hot silicone. My source of inspiration E60-E61 case was the orange leds on the stop and headlights of BMWs, I wanted to do such an application, since the light did not reflect as the 307 fender level ... When I saw with it, I drilled slowly with dremel when I saw that the tip was fully seated. I inserted the LEDs and applied it to be fixed with hot silicon immediately. I separated the wires and continue the process. Then I took the additional line on the stop scheme to burn with stop. and I do I think it was a. Photographs taken in the evening on the vehicle.
08.05.2020 16:59 # 2
sansasyon61
Well, my teacher is super happy
08.05.2020 16:59 # 3
kudret_yildirim
Well done, health on your hands ... it's beautiful.
08.05.2020 16:59 # 4
serkan206
What is this teacher, yaaaaaa ...
it was in the sight of the supreme :)
08.05.2020 16:59 # 5
jiyanxese
I'm super jealous
08.05.2020 16:59 # 6
fexzi
Thanks for the comments:) & nbsp;
Stops are for sale now.
08.05.2020 16:59 # 7
EErgul
It was number 10, but I do not dare to do something by cutting it. health explanatory expression in their hands
08.05.2020 16:59 # 8
Quite successful. Health to your hand.
08.05.2020 16:59 # 9
ginger
Thank you for expanding and effortlessly sharing our horizons.
I have not liked the application due to the difficulty of replacing the defective LED in the future, the aesthetic condition of the application in place and the application, it contains too much cable detail.
Although I do not know about the region, I thought that the same work can be done with the self-lined water-resistant LED.
Again, with the same led led operation, the LEDs in all headlight surrounds are flashing when the brake is applied and when the brake is applied. I wondered how the dirt in the middle would be more intense with the lights, what would be the result.
I hope I could explain it.
It is my personal ideas. > Health in your hand ...
ginger 2012-08-18 08:26:20
08.05.2020 16:59 # 10
Celalll
It was an inspiring work. I think it's good, health to your hand.
08.05.2020 16:59 # 11
fexzi
Thank you again.
To Ginger: I respect your comment. The answer I can give is that there is no harm to the electrical installation, just because the line is bought and the led legs are not extended, the electricity was given suitable for the installation to become active, there is no harm to the vehicle (it may cause 5te1 less damage from the sound system application). / div>
If you say why there is no problem with leds, it is fed with a resistance more than its value (lumen) and at the end of the circuit, the led manager is the electric current controlled diode and it is the least approximate (I am not saying led works that can be burned for at least 100,000 times) can cause damage. It was coated with a suitable silicon (black and yellow used for industrial waterproof circuit, not a home type), and then covered with a gray 0.2cm flexible styrofoam and applied to the vehicle.
Again thank you, best regards.
08.05.2020 16:59 # 12
ginger
What I mean by electrical component damage was the inherent concern of the application. Otherwise it will not do anything to the vehicle. But you have done so much practice for so many operations that it reminded me of the "re-discovery of America" as slang. It seems to me that if there is room in the same area, it would be possible if you mounted the ready led strip in the same design.
The work was done as you would do without these led strips, but it was replaced by self-adhesive leds.
08.05.2020 16:59 # 13
fexzi
[QUOTE = ginger] What I mean by electrical component damage was the inherent anxiety of in-house application. Otherwise it will not do anything to the vehicle. But you have done so much practice for so many operations that it reminded me of the "re-discovery of America" as slang. If there is room in the same area, it seems to me that it would be if you had installed a ready-made led strip in the same design. >
& nbsp;
:) strip led is not applied to all areas, at least for me, thanks.
08.05.2020 16:59 # 14
blinddark
What is the type of led you use Udadat
08.05.2020 16:59 # 15
Alicilik
[QUOTE = blinddark] What is the type of led which you use Udadat [/ QUOTE]
How many ohm single leds for 5mm led & nbsp; Reviews
08.05.2020 16:59 # 16
Gokhan Cetin
Emegine health, but it would be better if you connected them to the signals, as if the beautiful
sign
08.05.2020 16:59 # 17
rifatseker
[QUOTE = Receiveness] [QUOTE = blinddark] what is the led type you are using for overhead [/ QUOTE]
For 5mm led, how many ohm single leds & nbsp;
It determines the resistance working current and voltage for Led, every 5 mm Led is not at the same working current and voltage they give This ratio changes according to the colors. Below is a useful calculation tool, you can use it if you want.
08.05.2020 16:59 # 18
fexzi
How beautiful I did, but thank you for me: D
08.05.2020 16:59 # 19
Aziz
I really liked it, I thought of such an application as a writing in the bumper, and I did not dare to write a name with thin leds. I say if I do now :)
08.05.2020 16:59 # 20
emre_akdag
handmade, good luck :) good luck bye :)
Page : / 2
