Original in Spare Parts? Sub-Industry? Brands? |
| 08.05.2020 20:41 | # 1 |
| 08.05.2020 20:41 | # 2 |
sonerkyl |
I think my teacher wrote 306 instead of 307. my advice as a brand i would recommend rw - trw - delphi
| 08.05.2020 20:41 | # 3 |
If your budget is enough as a brand, always choose original. Price / component life is roughly the same as the original industry. Only the supply industry deteriorates more quickly. You go to industry more, it will be time consuming. If we come to the brand part, it changes from piece to piece. For example, in the sender, delphi, brake pad, tie rod etc. Trw is recommended. It is already clear from the price. One is a little expensive than the other. |
| 08.05.2020 20:41 | # 4 |
teskurrler teacher. The difference in price between what you say and what you say shows the quality. I appreciate user comments very much. tskler.
| 08.05.2020 20:41 | # 5 |
tskler teacher. I prefer to use delphi or riw-trw.
| 08.05.2020 20:41 | # 6 |
teacher; 2 DELPHİ z rot 60 TL 2 TRW tie rods 60 TL 2 DELPHİ tie rods 60 TL Delphi Ball Joint 25 TL. How are these prices in my teacher, is it double in ball joints or single? also front brake pad in one pair. FERODO brand
| 08.05.2020 20:41 | # 7 |
I came across maysan mando and wotto-teknorot brands. do you know about these brands?
| 08.05.2020 20:41 | # 8 |
[QUOTE = sociologist_56] also came across maysan mando and wotto-teknorot brands. do you know about these brands? [/ QUOTE] Prices are ideal, ball joints are sold as far as I know. I have entered the Maysan mando's factory in Bursa and I can say that without giving much detail, I did not bother me. We used Votto z rot to a vehicle you know was not a problem for 1 year. I heard the other brand for the first time. Addition; If the front discs are not original and not very scratched, grind finely on the lathe, if they are not original or if there is a lot of roughness, renew them as a tool. If the pad is not located quickly. |
| 08.05.2020 20:41 | # 9 |
sonerkyl |
prices are ideal as our friend said. The products of wotto and techno are not bad either. unfortunately, maysan products are cheap but not very lifetime that our friend said. Ball Joint is unique for every swing. I used the brake pad feredo.
