Original Allure Tape Installation to Peugeot 301 Active
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 21:30 # 1
mahmutr
Hello Guys, Ladies.
I will help you with 301 Active cars and who want to install and install Allure. A few weeks ago @ groundcover @ Gökhan `ten despite not wanting that help did not help me with my own means I want to share with you also learned how to hang.
First of all, you only need to buy a microphone to talk with the USB & Aux Cable and Bluetoolt. If you think these are not important to me, there is no need to work without any problems. Without the need to plug in extra wires, the trip computer, bluetoolt works smoothly. I did it myself. However, one sound per second comes because of its lack of coding. Take it to the tape recorder, connect the vehicle to the machine and handle it in 10 minutes, processing your chassis number to the tape recorder.
I do not have many pictures in my hand, but you can easily do so in the order I will explain.
As Evidence Of What I Do:
Before:
After:
When you remove your old confirmation, you will be greeted with 2 cables at the back. One is a white radio antenna cable and the other is a 20-25 cable harness. Remove this harness from the back of your tape. When you disassemble and look in front of the harness, you will see that each cable entry is given a number.
Yes, it is very good if you have come here without any problems. Now I will tell you 4 cable numbers. Melt these cables from the proper place and make the iron visible in it. Because we will remove and connect the screen from those cables.
Tape Screen
10 --------------------------------- 4
12 --------------------------------- 1
13 --------------------------------- 6
16 --------------------------------- 3
There are 6 pin inputs on the screen, we will use only 4 of them. There is a socket on the screen, but I could only find Aliexpreste only. I ordered from there, but it will take a long time. That's why I took it out from 301, which was a curtain in sams.
If you have any questions, I can help you send mail to mahmutavsarr@icloud.com.
29.08.2020 20:16 # 2
mahmutr
+ UP.
31.08.2020 21:58 # 3
hasankose15
The 301 is the most economical ideal sedan and is above its value in terms of comfort
02.09.2020 23:46 # 4
ekremozsoy17
I will buy a sedan vehicle, I think 301 is both good in performance and affordable in price
05.09.2020 19:37 # 5
hilmiaksu05
The interior is also comfortable and convenient for a 301 suitable car sedan
07.09.2020 23:26 # 6
hasankose15
Our 301 company car is not flat but an ideal vehicle in the city
01.11.2020 10:49 # 7
mahmutr
+ Up
06.04.2021 08:48 # 8
mahmutr
+ Up to date!
20.06.2021 22:12 # 9
mahmutr
+Up Update !
10.08.2022 13:06 # 10
mahmutr
+Up Update !
10.11.2023 11:32 # 11
yusufkaya0661
Hello, can't we connect it directly to the tape recorder without taking any live leads, that is, without stripping the cable?
