Orange Plastic in the Engine Compartment
08.05.2020 20:55 # 1
x571
I saw something like an orange plastic bag swinging from the bottom of the car's engine compartment. what is the protector of this, do we need to renew it? Does that place have any problems in the open now
x571 2018-06-20 17:42:30
08.05.2020 20:55 # 2
as far as I can see, there must be a dementia dust blower.
08.05.2020 20:55 # 3
x571
[QUOTE = sonerkyl] As far as I can see, I need to have a dementia dust blower.
No, my teacher came out of the orange plastic. The bright iron varya that I marked from the hole on the right of the photo had passed there. The other side was torn a little while tugging
x571 2018-06-20 19:57:16
08.05.2020 20:55 # 4
This is the first time I see it very strange.
08.05.2020 20:55 # 5
x571
[QUOTE = sonerkyl] This is the first time I see it very strange. [/ QUOTE]
I saw it for the first time. I even thought something was stuck. What is the bright iron piece marked with a red rectangle? what does it do
08.05.2020 20:55 # 6
the steering wheel looks like a hydraulic lever, where it is connected to the metal shiny part, if it is going to the wheel, if the route is connected, they may have wrapped it because there is no bellows.
08.05.2020 20:55 # 7
x571
[QUOTE = sonerkyl] looks like a steering hydraulic arm from here they may have wrapped this because the metal is attached to the shiny part, if it is going to the wheel, if the route is connected, there is no bellows [/ QUOTE]
Does that make it a problem if it doesn't happen? is it dust or mud
08.05.2020 20:55 # 8
Honestly, you saw that when the axle of a vehicle was removed, I saw it when the steering gear was removed, tie rod etc. I saw this kind of material for the first time, and I think it is not the original one you removed. this piece came out from the left, is there something similar, right? I still think it is dust blower.
08.05.2020 20:55 # 9
Karacocuk24
I think if your piece is not in the packaging
