*** Operation with direct lpg in sequential system ***
08.05.2020 16:55 # 1
simurg
*** Direct lpg execution in sequential system ***
In line system vehicles, we have the possibility to work with direct LPG in case of running out of gas or the pump of the diaper.
I think there is good information for emergencies ....
but I do not know if I want to operate this way every day ... I do not know if it would be a problem .... ....
simurg 2012-07-18 14:22:04
08.05.2020 16:55 # 2
Barut
Thanks for sharing useful information & nbsp; "Thumbs
08.05.2020 16:55 # 3
Operating this way is particularly harmful in damp or cold weather and can lead to malfunctions. As you know, LPG coming from the tank turns into gas in the evaporator. The evaporator takes its heat from the temperature of the engine's coolant. If you run it directly on LPG, it may not be gaseous. Especially if the weather is damp or cold, the incoming LPG will freeze directly. Do not say that nothing will happen in summer because it can freeze up to 25 degrees. I think it shouldn't be used except in very essential situations.
08.05.2020 16:55 # 4
C@GL@R
the engine does not work when it is cold, especially in winter. but if it runs out of gas somewhere on the road, it's a useful feature
