operation of the wipers with the ignition off.
08.05.2020 17:11 # 1
baha1907
Hello friends
2004 Model 2.0 I have a Hdi Partner & nbsp;
Today I parked my car and removed the ignition from its socket. It came to my mind to operate the wipers and I touched the wiper arm, the wipers worked worked. half an hour passed, I came back to my car. I put the contact back I removed the wipers worked :) what could be the reason for this problem. the car can cause problems in working in the morning, sometimes it does eat the battery car: S
08.05.2020 17:11 # 2
Serkan
Not a problem man, this is perfectly normal, about 1 minute after turning off the ignition, bsi goes to sleep, they wipe until they go to sleep, and the window opening and closing works.
08.05.2020 17:11 # 3
baha1907
After turning off the ignition, the sound of the vızzzzz die is about a minute, even if it is a little in the engine part of the vehicle. Two months ago, the engine was running low on water and a few lights were on, bsi & nbsp; was said to be faulty and repaired and did not give the old error. Then I get it wrong with all bsi vehicles: S & nbsp;
08.05.2020 17:11 # 4
EnSoNiQ
you know correctly, I know that this is going to sleep 1 minute after the contact in vehicles with bs.
08.05.2020 17:11 # 5
baha1907
As far as I know, you can try this event in all pejos. Try to operate the wipers without installing the contact, it should not work. & nbsp; then insert the contact and turn it halfway, then remove the contact and try the wipers again, if the wipers work, my vehicle is normal & nbsp; and I will be comfortable :))
08.05.2020 17:11 # 6
Serkan
No need to try, man, I have done the same thing before, you can not remove the wipers so that the wipers do not freeze in the winter 308, the wipers will remain under the hood if you pull the wiper arm down once you pull the ignition, the wipers will remain in the open position, but they are the same in other peugeot, but the 206 is also not needed under the hood. will be heard
08.05.2020 17:11 # 7
tellotello
I have the same situation. So there is no problem in your vehicle. Something very logical is both helping to remove the wipers as the friend said, and even if I pulled the key from the contact, I had the opportunity to close it, even if I forgot the open window or something, I would have to deal with putting the key again. When Bsi goes to sleep, everything sleeps in the car. & Nbsp;
08.05.2020 17:11 # 8
baha1907
* Are you talking about standing upright to the surface when you say that it works to lift the wipers? so the wipers don't stay there, hmmmm :))
08.05.2020 17:11 # 9
Serkan
[QUOTE = baha1907] * Are you talking about standing upright on the surface when it says it helps to lift the wipers? so the wipers don't stay there, hmmmm:)) [/ QUOTE]
Yes, sir, exactly ...
08.05.2020 17:11 # 10
Alicilik
[QUOTE = Serco05] No problem, man, this is perfectly normal, about 1 minute after switching off the ignition, they will go to sleep, they will wipe until they go to sleep and the window will open and close. [/ QUOTE]
until you open the door "Big
