Opening fog light
08.05.2020 17:09 # 1
yagiz35
I remember seeing friends before, but I couldn't come across this issue again, there is no fog light in my bumper, can it be made later, if it is made, is it different from the original or can they do it very close to the original? Experienced friends, I would be very happy if you can give information
08.05.2020 17:09 # 2
Alicilik
Where is Ramadan? Ramadan?
I know that Mehmet (memotech) had a brother built. It had its subject. He will surely look when he comes.
Mehmet brother, look at this CC too here "LOL" < br>
08.05.2020 17:09 # 3
Serkan
Take a look at the following issues Yağız, Ali Ramazan, after the lost battle, Mehmet CC, after the fog in Ramadan, they did not suffer :)
http://forum.peugeotturkey.com/forum_posts.asp?TID=16362&title= end-gave-206-sis-far-iin-abalarm
http://forum.peugeotturkey.com/forum_posts.asp?TID=24229&title=206-s%DDs-takmak-ok- easy
Serco05 2012-11-22 22:54:52
08.05.2020 17:09 # 4
caster21
My advice to you is not to pierce the bumper, because it is made of a very sensitive material, there may be cracking around it. If you do not make a good master, give the bumper to the scrapper.
08.05.2020 17:09 # 5
yagiz35
When I buy a buffer, there will be a paint cost, but I think there will be a difference of 200 to 250 pounds is it wrong?
08.05.2020 17:09 # 6
Alicilik
[QUOTE = caster21] My advice to you is that it is made of a very sensitive material that you do not pierce the bumper, you can crack it around. > +1 Member Reviews
08.05.2020 17:09 # 7
MemoTech
Brother, first of all, the fog lights you get should be correct, so the fog should match with your bumper, GTI fog is different, you will get the normal fog light and if you want to cut it, you will cut it a little bit from inside the lines. you have to stay inside without cutting. It is not a process to be afraid of.
08.05.2020 17:09 # 8
yagiz35
then, I will reach the conclusion without any problems with a good master, & nbsp; thanks & nbsp; for help & nbsp;
