Opening / Closing Windows with the 208 GTI Switch
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 19:24 # 1
HeroKing
Hello friends,
In my 2015 model 208GTI, I could not activate the opening and closing of windows with a remote control.
I tried to hold the control for 300 seconds, lock the doors from inside the car, press the glass on / off keys, etc. but I did not get any results.
When I asked the dealer, I did not get an answer.
I have this feature in my car.
Thanks for your answers.
08.05.2020 19:24 # 2
My teacher probably needs coding, but of course, opening and closing these windows needs to be done in a certain order in the 307s. It is an excerpt.
if it is in the same logic as the old models, you have to introduce it;
you open the ignition of the vehicle halfway.
You press the button to lower the windows, and after the windows come down, you press the button for about 5 seconds.
then you pull the knob up, the windows close, and you hold the knob for 5 seconds with the knob pulled up and the necessary adjustment is made.
This happens in our 307s, if the system logic is the same, you will have it too.
08.05.2020 19:24 # 3
HeroKing
Thanks buddy, I tried, but again I did not get any results: /
08.05.2020 19:24 # 4
Oguz BOR
If you have an ecufast branch in the city you are in, you can open the hidden feature. I am K.maraş branch, some of our branches are doing.
08.05.2020 19:24 # 5
HeroKing
[QUOTE = Oguz BOR] You can unlock the hidden feature if there is an ecufast branch in your city, go to a problem. I am K.maraş branch, some of our branches are doing. [/ QUOTE]
Thanks for your answer, I asked in Bursa, unfortunately, they said they couldn't.
08.05.2020 19:24 # 6
Alicilik
Whether it supports the bsi related or not. There are parameters, but as I said, the bsi and the glass control lever need to be dictated.
08.05.2020 19:24 # 7
Leprek0n
I have 1.6 THP Allure, which is not controlled from the windows. Leprek0n 2015-08-18 21:19:05
08.05.2020 19:24 # 8
HeroKing
[QUOTE = Leprek0n] I have 1.6 THP Allure, which is not controlled from the control windows [/ QUOTE]
It seemed ridiculous to me, although the vehicle supports this feature, it is very interesting that this event is not drawn at all.
08.05.2020 19:24 # 9
Leprek0n
The disadvantage of the Peugeot comes out in such things, though vw does not necessarily have a way in such events (like Vagcom).
08.05.2020 19:24 # 10
DeRyCK
I tried many things, but it never happened.
