Open Air Filter Cleaning |
| • Homepage » PEUGEOT MODIFIED PLATFORM » 206 | |
| 08.05.2020 15:16 | # 1 |
tigerland |
It was about 5000 km and I cleaned the open air filter. With the air gun, we first take the dust and squeeze the cleaning spray on it, then after rinsing with water, we remove the water from the pores again with the air gun. After wiping thoroughly with microfiber cloth, we lubricate the pores so that they do not close and they are clean. Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us
| 08.05.2020 15:16 | # 2 |
Serhun |
Thanks for the information and photos. It has been a very good work, I wish you goodbye.
| 08.05.2020 15:16 | # 3 |
tigerland |
Thanks to the engine so that we can get clean and fresh air, here is 5000 too :) the cleaning kit really works.
| 08.05.2020 15:16 | # 4 |
metin |
good work health
| 08.05.2020 15:16 | # 5 |
tigerland |
Tşkler. thank you text but there is a kit more room cheap simota air filter cleaner 19.90 :)) |
| 08.05.2020 15:16 | # 6 |
metin |
I think k & n in-box open air filter for my 307 is 90 TL if fortune.
| 08.05.2020 15:16 | # 7 |
deamod |
can i get a link ..
| 08.05.2020 15:16 | # 8 |
metin |
[QUOTE = Erb's] Tşkler. thank you text but there is a kit more room cheap simota air filter cleaner 19.90 :)) [/ QUOTE] Hello, can you send me a link? I have to clean the open air filter, but K&N 75 TL, jsv pattern 35 tl. If Simota is still 19 TL, I'll get it right away. Also, if you have a short-term measure, I can do it as well. some said clean with balata spray, some said put it in gasoline etc. If there are any, I can listen to them.
| 08.05.2020 15:16 | # 9 |
tigerland |
i have simota finished jsv i'm glad i'm using it
| 08.05.2020 15:16 | # 10 |
Beautiful Work Skateboarding ...
| 08.05.2020 15:16 | # 11 |
tigerland |
[QUOTE = AlbaYDemircaN] Beautiful Work Makkargir ... [/ QUOTE] Thank you, Colonel. I clean around 5 thousand km, if you see the dust coming out of the dirt, you will clean it in 2 thousand :)) The kit works, I recommend you to clean it in 5 thousand of friends who use an open air filter.
| 08.05.2020 15:16 | # 12 |
My friend, first of all thank you for making us share. I have a simota carbon in the same, I was always wondering, but I have another question, mine got rid of the handcuffs, I left the filter for 2 days with the filter separated, I immediately got the engine turned on when I noticed (I am sure it was 2 days ago because I had a problem with the engine 2 days ago. ? what should I do? There is a drop in reaction when eating gas in the vehicle, especially in the poor
| 08.05.2020 15:16 | # 13 |
metin |
[QUOTE = Erbin] simota has finished JSV I'm glad I use it [/ QUOTE] thank you.
| 08.05.2020 15:16 | # 14 |
tigerland |
[QUOTE = text] [QUOTE = Erbin] simota finished JSV I am using it I'm glad [/ QUOTE] thank you. [/ QUOTE] eyw. Thank you when you see the dirt while cleaning.
| 08.05.2020 15:16 | # 15 |
EmSul |
My open air filter is normal open, there is no protective thing like yours.
| 08.05.2020 15:16 | # 16 |
the performance filter I bought from this filter. When you drive the car at high revs, you get a very sweet sound. The advantage of being carbon allows it to cool quickly and sometimes it does not even heat up. As the friend says, it is used for many years if it is cleaned in maintenance. but my advice to you is to assemble it well, or it may come off. I advise.
| 08.05.2020 15:16 | # 17 |
cey cey |
Thank you to a friend who has been a beneficial process ... I am cleaning a thousand km thousand km is healthier but for the first time I heard something called lubrication what do you lubricate erbin air filter?
| 08.05.2020 15:16 | # 18 |
Barut |
What is this cold air gun, is it expensive?
