open air filter
08.05.2020 17:15 # 1
dogukan_1987
Friends good forums vehicle 106 1.4 xr exhaust is not surrounded by the cops, I do not think but I would like to have an open air filter, do you suggest that I make a sound or would you please give information about the exhausting ones that make a lot of noise?
08.05.2020 17:15 # 2
dogukan_1987
nobody has any idea & nbsp;
08.05.2020 17:15 # 3
_semihk_
I say you have a valve with exhaust .. air filter is not my style .. It is said to increase the fuel continuously: S
08.05.2020 17:15 # 4
dogukan_1987
I heard that the exhaust burned a lot, my teacher and I missed the valve after a while
08.05.2020 17:15 # 5
herry
simota carbon hafa filter with boiler you get the full sound you want to shout at your hands i can roar in 2000 cycles, event & nbsp; it is not necessary to go out 4 5 thousand to be able to catch that sound.
I received 120 TL from Aksaray.
08.05.2020 17:15 # 6
dogukan_1987
Where can I get it? Does anyone have knowledge in Ankara? When I go over 3000 cycles, I say enough.
08.05.2020 17:15 # 7
herry
As I said, you cannot understand without using it in 4 thousand cycles. You have the opportunity to go without screaming at the air filter. the filter that I recommend to you is one of the most plump and not easy to heat (it makes it wrong because it is the type of the boiler, it makes the sound so hot and it does not heat up easily because it is covered with carbon again)
Let me put a sample picture, I hope it helps you to order it, you can order it anyway. You can get it from the site, it is very easy to install, you can also make the connection to any auto mechanic or accessory.
http://www.lastiknoktasi.com/image/cache/data/simota%20hava%20filtresi-350x470.jpg Reviews
08.05.2020 17:15 # 8
dogukan_1987
ok thank you I am researching my teacher & nbsp;
08.05.2020 17:15 # 9
joraskimi
Well, I made the filter kit myself. all the friends were laughed at the first love from the pinhole pipe :) it was like the filter kit from pimaş but when I finished the work and pressed the gas, they were all surprised. I will upload your pictures, if you have some skill, you can do it yourself. Also cost 10TL excluding filter :)
08.05.2020 17:15 # 10
joraskimi
Remove the middle muffler with the catalyst instead of installing the bidet exhaust, install a 51 pipe, sound number ten.
08.05.2020 17:15 # 11
dogukan_1987
Hoam, I travel a lot in the city, the cops are in trouble, so I can't get it fixed & nbsp;
08.05.2020 17:15 # 12
herry
at the last inspection they looked at the catalyst and also looked at the exhaust from under the vehicle ..
08.05.2020 17:15 # 13
fexzi
If you buy a filter suitable for your vehicle's cylinder volume, there is no sound during normal use cycles, a sudden and dense sound is heard from the filter during sudden movements. there will be more performance in winter conditions.
08.05.2020 17:15 # 14
dogukan_1987
Would you recommend fexzi teacher?
08.05.2020 17:15 # 15
herry
[QUOTE = fexzi] If you buy a filter suitable for the cylinder volume of your vehicle, no sound will be produced during normal use cycles, a sudden and dense sound will be heard from the filter during sudden movements.
The purpose of the air filter is to draw more air, it burns quickly, so there will be more performance in winter conditions.
1.6 How big would you recommend for 206? Reviews
08.05.2020 17:15 # 16
silivriserdar
What do you need? It consumes more fuel. But of course it's a matter of taste.
08.05.2020 17:15 # 17
fexzi
[QUOTE = herry] [QUOTE = fexzi] If you get a filter suitable for your car's cylinder volume, no sound will be produced during normal use cycles, a sudden and dense sound will be heard from the filter during sudden movements.
The purpose of the air filter is excessive. By drawing air, it enables the vehicle to burn the fuel more quickly, so there will be more performance in winter conditions.
You get the filter that best fits the 1600 cc volume in the criteria you are looking for, there will be no such thing as excessive fuel, it will be 5.3lt if it burns 5 lt.
08.05.2020 17:15 # 18
dogukan_1987
the war is very unstable :) they say it is too close if I do not get it done, they say bidet & nbsp;
08.05.2020 17:15 # 19
herry
I had the simota carbon, I was very happy in the summer months, and my master put it on, I liked his performance. I would recommend it in these months. Believe me, if you do not change or if you are not going to hang in the traffic that is subject to me, everyone will look at me. Unfortunately, I gave a gift to my friend, now I want to buy a new one. But there are the deadlines for the 1.6, which is the most suitable one, I will search for it. And this time I want to make the pipe work extended from the engine more smooth.
08.05.2020 17:15 # 20
dogukan_1987
Hodja, you told me what is suitable for the 1.4 engine, but I do not want to use it in the bidet summer.
Page : / 2
