On headlight imbalance and spoiler
08.05.2020 16:19 # 1
106GTJ30
Reviews Friends tool in my I want to remove the spoilers I sevmiyorum.b but disconnect after there will be a gap if gibi.ill to wax the paint gerekecek.iste I spoilers I yok.san in turkey I need to specially make you know about this bodywork spoilers & nbsp If you have a specialist, I would appreciate if you help with a private message. I will do the same I will send the photo. I feel like it would be salty, but I get it full when I did it. But I definitely do not want this spoiler to come out.
2 questions and problems I just bought and started using hk brand angel headlight with yellow led. especially left headlight problem. height can be adjusted but left headlight beams a little to the left (shorter). That's right. What can I do about this? I didn't have this problem in my original headlights. It seemed very strong in the long years, though I haven't tried it on the highway yet.
08.05.2020 16:19 # 2
For the spoiler, you need to search for a high-quality barber who does this. If there is any information from the author, the author is already there. In some angel headlights, short and long settings are different. It may be necessary to adjust and adjust the pain. I also use angel headlights in my car and I have adjusted angel headlights to other friends. Nothing works when it is not properly adjusted. But if it is set properly, you will be satisfied ...
08.05.2020 16:19 # 3
I designed my desire that knows all the turkey's dealing with both izmirdeymiş of seeing this work helps you wer there in Abdullah had a brother, but you special construction helps me tlf war there were divided Official warsa is enough for spolier ... "Blink" "Blink"
08.05.2020 16:19 # 4
106GTJ30
thank you cecoli can you give some information about this setting. how could i not do it myself, because i just take it up and down when i take it. do i need to disassemble the headlight?
08.05.2020 16:19 # 5
106GTJ30
My original headlights motors were removed and installed in hk. They put them in the headlight setting again, a different device was used. It is much better now. I am still thinking about installing xenon.
