On 206+ gasoline wipe with engine cold. (Problem Solved)
08.05.2020 15:25 # 1
hunterakon
masters friends:) 206+ 2011 I had my car lpg in the last months. Recently, when the engine was cold (morning and evening work out), a 5 10 seconds after the car started, the kicking was kicking. accelerates, that is, it circulates. After a while, when the engine is hot, there is no problem when the engine is hot. There is no problem in LPG, but there is a problem in the gas. The vehicle has an LPG warranty. do we have a master
Thanks to my friends for a long time, I have solved the shaking problem as of yesterday. Thanks to the LPG assembly, it was caused by the wrong assembly. The complete LPG assembly of the vehicle was dismantled.
the hunterako 2011-08-12 08:47:49
08.05.2020 15:25 # 2
fTh206
There is a lpg setting, maybe it is because of a passing arc, it was like kicking stop etcek or something.
08.05.2020 15:25 # 3
Definitely look at the calibration settings. Only the master who assembles the lpg system makes these settings.
08.05.2020 15:25 # 4
hunterakon
I took the lpg, it was very open, said the setting was bored, this time the vehicle is not going 130 but I saw the ramp below: D did not have a middle of it or when it said it was too open, it was rarely needed to open it again I can't understand these lpg cers anymore
08.05.2020 15:25 # 5
hunterakon
Erciyes industrial site, there is a mature LPG. I took the vehicle there. The guys who were the local dealers of landirenzon were the guys who were actually assembling LPG to the vehicle. he said ... it suddenly tortured me as if boiling water was pouring out of my head, waiting for the morning to come: D
I was going somewhere with my uncle bidet, he was driving, he drove from 4th gear to 3rd gear, he said that there was no compressor in this car, he said that he had to stack up from big gear to small gear, yes, it does not stack up. It is proof that it is not, but on the one hand, even if it is a vehicle, the vehicle never goes and it seems to me that it burns tomorrow.
08.05.2020 15:25 # 6
my head was confused :))
First of all, you just said there was shaking in your gas. Then you went to LPG. Although the setting of LPG is corrupt or smooth, it does not affect the operation with gasoline. If it is shaking in gas, you have to look at its reason.
08.05.2020 15:25 # 7
hunterakon
but they said they can do this caking because of lpg. why did he say
If the lpg of the vehicle is low, the engine brain could not calibrate it with gasoline and said that it could do so. )
08.05.2020 15:25 # 8
but if the lpg was too hoarse, wouldn't the fault light burn because of my poor wife ???
08.05.2020 15:25 # 9
BAHTIYAR
First of all, I do not have enough information about the subject, but only one car in Ankara does not look at it.
08.05.2020 15:25 # 10
ose
my friend lpg your problem. It's nothing else. If it is re-circulated, remove the pole head so that the vehicle will take out the fuse of the tube, and you will see it in the cable out of the pole head. Put on the pole of the vehicle and use it for gasoline maintenance, does it ever crawl? It's all about lpg's software.
08.05.2020 15:25 # 11
kankam_743, hunterakon says "it is recovering after a while while the engine is hot while switching to the gas, there is no problem in the lpg, but there is a problem in the gas" and you say "my friend is your problem lpg." Is it necessary to remove the fuse after turning off the LPG button and switching to gasoline?
08.05.2020 15:25 # 12
hunterakon
badires friend so clear and beautiful explained that I don't have to say anything :)
On the lpg of the vehicle, there is no problem at all. On the contrary, the lpg also goes as fast as I want, with the traction I want. And as my cecoli master said, the lamp does not come on absolutely or absolutely during low or open.
If my old friend says that the lagoon and the abc are looking, I will not really take my step or step. I get permission from the workplace and I go to the lake, I'm tired of my friend Ozamn.
08.05.2020 15:25 # 13
[QUOTE = hunterakon] my badires friend explained so clearly and beautiful that I didn't have to say anything :)
goral rapid go konya way shell will definitely find a solution there in the gasoline.
08.05.2020 15:25 # 14
ose
[QUOTE = badires] kankam_743, hunterako says that "after a while over the hump no problem no LPG also be a problem when the car engine is hot during the passage of gas but gasoline is making a nuisance divide" and you say "friend your problems LPGA." Is it necessary to remove the fuse after turning off the LPG button and switching to gasoline? [/ QUOTE]
The problem is that when we first start the car, the LPG software changes the fuel rate that the car burns while in petrol, and the result is stalling. My vehicle stops repeatedly until I switch to LPG. There is no click after switching to LPG. Is my problem from the engine? I have taken out the fuse of the LPG, I took off the pole, I put on the bikes for 1 week in gasoline did not stop at the moment. I will go and add new software. I mean try it and will it still crank? Of course, cem master knows better, he should get his comment. kankam_743 2011-05-22 00:34:42
08.05.2020 15:25 # 15
flash296
the cousin had the same problem too ... disassemble this lpg ... i did so ... do it too ... mine GTI ... don't think about the lion-feeding vow friend ... stay the original of the car somehow ... damn Whether lpg ... whatever happened to me after lpg. nice, I didn't have any trouble in lpg, but after installing it, problems started ... lastly let me change the crankshaft sensor. then it will be ok! respect everyone ...
08.05.2020 15:25 # 16
hunterakon
Now, take the LPG off, but it's fine, but you end up paying a lot of money and damn that our gasoline is the same value as gold, when we use an airplane. I say 1800 km is going !!! Beyond there, brother, 1800 km what it means, 1 liter of gasoline and 30 km of road joke. They will put it in Mazda 3.
08.05.2020 15:25 # 17
ose
Does caking continue? the hunterako
08.05.2020 15:25 # 18
hunterakon
Yes, it continues. I have noticed that the vehicle is idle, I press the clutch, I press the gas, I leave it over 1000 cycles. 2 3 seconds later, it is as if it would stop and stop the morning.I said I would go without waiting for that process.
08.05.2020 15:25 # 19
metin
[QUOTE = hunterakon] yes it continues I paid attention to the car idle, I press the clutch, I press the gas, I leave it over 1000 cycles, 2 3 seconds later, it is as if it was going to stop and stop, I said I would go without waiting for that process in the morning, the ramp was in the garage of the house. [/ QUOTE]
Did you look at the throat butterfly?
08.05.2020 15:25 # 20
ose
Look, my cycle was falling in gasoline and constantly stopping. I took off the pole and wandered around for a week, then I went to get the LPG calibration again, I don't have a click for a week now. I don't know how many kilometers your vehicle is in 2011, why should the new vehicle be a problem?
Page : / 5
