Oily water draining piece
08.05.2020 21:28 # 1
x571
When opening the cap, water flows from a piece on the right when the vehicle is parked. Flows drop. On the piece, it says "Atiker" is probably a piece about LPG. The dripping water is a bit oily, probably not evaporating. A wet mark stays for a long time. Why does water flow from here? What can be boredom?
08.05.2020 21:28 # 2
talip206
The lpg regulator is called the lpg brain in most places. There is a material called diaphragm inside, probably it is old. Most lpgists say they will change completely. In some places there are diaphragm repair kits. But they usually prefer the first method.
Check the engine water level frequently, if it is dehydrated, it will turn your head on.
talip206 2020-02-28 18:32:08
08.05.2020 21:28 # 3
x571
[QUOTE = talip206] The lpg regulator is called the lpg brain in most places. There is a material called diaphragm inside, probably it is old. Most lpgists say they will change completely. In some places there are diaphragm repair kits. But they usually prefer the first method.
Would it be like being pierced suddenly and leaving it on the road? If we postpone the repair to summer or something?
08.05.2020 21:28 # 4
talip206
How much leak is he doing. How about the lack of water. Well, the cooling issue is very risky. If there is no water left on the road, the gasket burns 10 times. It is necessary to check every day.
08.05.2020 21:28 # 5
x571
[QUOTE = talip206] How much leakage does he make. How about the lack of water. Well, the cooling issue is very risky. If there is no water left on the road, the gasket burns 10 times. It is necessary to check every day. [/ QUOTE]
Sometimes a few drops, sometimes a teaspoon or a teaspoon, depending on your head. I also searched on the internet, when this change is said, the renovation report and sealing are requested. Is it correct? Is it still implemented? How much workmanship is required to change this.
