Oiling on the engine
08.05.2020 16:32 # 1
phoenix.1905
Friends, I opened the hood of my car today, I saw lubrication on the engine .. I used to check the oil continuously before, and the oil did not decrease.
08.05.2020 16:32 # 2
dukenukem82
stems from the seal renew the seal and less load on the engine & nbsp;
08.05.2020 16:32 # 3
yavuz25
a very small leak. I think it will not cause trouble. "Wink"
08.05.2020 16:32 # 4
phoenix.1905
I will travel about 100 km tomorrow. I can't show it to a master before I leave. Will there be a problem? Is this oil leak serious?
08.05.2020 16:32 # 5
yavuz25
[QUOTE = phoenix.1905] I will drive about 100 km tomorrow. I can't show it to a master before I leave. Will there be a problem? Is this a serious oil leak? [/ QUOTE]
nothing will happen with that much oil leak insha'Allah "Wink" .Do not worry.Let your way open. "Wink" Trust God.
08.05.2020 16:32 # 6
saivet
nothing much oil will check my oil if nothing is missing in the bottom of my engine. title = "Thumbs Up" />
08.05.2020 16:32 # 7
206206
& nbsp; that much lubrication happens in my vehicle & nbsp; master no problem & nbsp; and nbsp; he said from sweating or something, & nbsp; I didn't open the hood again. & nbsp; No problem if it doesn't drip on the bottom
08.05.2020 16:32 # 8
206206
[QUOTE = saivet] Nothing will be more fat than mine. Check the oil of my engine is nothing in the bottom oil check if it is not missing. [/ QUOTE]
lonely friend & nbsp; issues & nbsp; opened in January & nbsp; :) "Smile"
08.05.2020 16:32 # 9
saivet
I already noticed that I have just noticed that I have already built a new engine so far "Big
08.05.2020 16:32 # 10
206206
maybe he even changed the car:) "Smile" 206206 2012-05-27 02:58:24
08.05.2020 16:32 # 11
toga406
Nothing happens, think sweating has done
it doesn't have a mite
08.05.2020 16:32 # 12
phoenix.1905
Well, the master had tightened that screw in January, when I saw the oil in the same place last week, I tightened it. How are those oil scars removed?
08.05.2020 16:32 # 13
phoenix.1905
Also, leaks started to occur under the gasket surrounding the engine. Will the replacement of the gasket solve the problem? Is it a costly job?
08.05.2020 16:32 # 14
monur
[QUOTE = phoenix.1905] Also, leaks began to occur under the gasket surrounding the engine. Will the replacement of the gasket solve the problem? Is it a costly job? It is known that the weather has warmed up and after the motor comes off the road, it cools later than normal time. It is quite normal to have oil sweating in such cases. If you do not get inside, you change the rocker gasket and your problem is eliminated to some extent. This is a 5-minute job.
08.05.2020 16:32 # 15
phoenix.1905
I guess it would be better if I replace the rocker gasket. Let's also tighten those screws with torque. & Nbsp;
08.05.2020 16:32 # 16
toga406
Sold for 15 TL engine cleaning spray dissolves perfectly. even flowing over. Take it and don't be afraid of the motor frequently. I did it was perfect.
is pushing both dust.
