Oil warning warning
08.05.2020 20:22 # 1
emrahi
Good evening guys. There is a problem in my vehicle as follows: When I do not start the vehicle for more than 1 day, the first time, the oil warning warning appears, chirping, and after 2 seconds the light goes out and the vehicle returns to normal. As long as I run it daily, I did not encounter such a problem, but when I take a break for 1 day, this problem occurs with the first start. I look at the oil level, the oil has changed at 44 thousand km and now it is 48 thousand. If I go to the service, I give my hand and get my arm :)) Has anyone experienced such a problem, it would be very acceptable if anyone can help. Clap
My vehicle pevgeot 208, diesel, 48 thousand
08.05.2020 20:22 # 2
x571
[QUOTE = emrah] Good evening, friends. There is a problem in my vehicle as follows: When I do not start the vehicle for more than 1 day, the first time, the oil warning warning appears, chirping, and after 2 seconds the light goes out and the vehicle returns to normal. As long as I run it daily, I did not encounter such a problem, but when I take a break for 1 day, this problem occurs with the first start. I look at the oil level, the oil has changed at 44 thousand km and now it is 48 thousand. If I go to the service, I give my hand and get my arm :)) Has anyone experienced such a problem, it would be very acceptable if anyone can help. Clap
go to industry you change 50 pieces.
08.05.2020 20:22 # 3
pusutr
I think buy and replace the original oil filter and suitable oil. The engine does not come to this negligence.
08.05.2020 20:22 # 4
emrahi
I also think of changing the oil and filters first, I called the service, they did not use it other than the total, but I will take the mobile formula esp and change it, I talked about it. I check your oil, it seems too much to me and the other part of the job is that the car service is well maintained ... I bought the car 1 month ago. emrah is 2017-05-23 11:59:23
08.05.2020 20:22 # 5
my teacher, this type of problems can usually be caused by oil and oil filter. As my friend says, I use mobile oil like you. Smile . Some employees do not pay much attention in the service, they may have closed and filled the stopper before the oil was completely drained. This can lead to error-like problems you receive.
08.05.2020 20:22 # 6
emrahi
[QUOTE = sonerkyl] my teacher, this type of problems can usually be caused by oil and oil filter. As my friend says, I use mobile oil like you. Smile . Some employees do not pay much attention in the service, they may have closed and filled the stopper before the oil was completely drained. This can lead to error-like problems you receive. [/ QUOTE]
I just ordered my mobile 1 esp 5-30 oil, I will take the oil myself and go to the service periodically. I will have periodic maintenance not only oil change. I hope I pulled a lot from my previous car, I hope this car will make me smile ...
08.05.2020 20:22 # 7
talip206
It is also beneficial to have the battery measured. When it works one day later, it may also make it think. Other possibilities have already been said.
08.05.2020 20:22 # 8
emrahi
[QUOTE = talip206] It is also useful to measure the battery. When it works one day later, it may also think about it. Other possibilities have already been said. [/ QUOTE]
If the battery is weak, is the oil warning lamp on? I did not connect much, I do not know much, I would be glad if you open the subject a little.
08.05.2020 20:22 # 9
talip206
[QUOTE = emrah] [QUOTE = talip206] It is also useful to measure the battery. When it works the next day, it may also think about it. Other possibilities have already been said. [/ QUOTE]
In our vehicles, deflection is famous when the battery is weakened. In general, interesting situations can emerge in signs and similar places.
But of course, as friends say, the first place to look is the oil filter.
08.05.2020 20:22 # 10
emrahi
[QUOTE = talip206] [QUOTE = emrah] [QUOTE = talip206] It is also useful to measure the battery when it runs the next day, it may also think about it. Other possibilities have already been said. [/ QUOTE]
But of course, as friends say, the first place to look is the oil filter [/ QUOTE]
The oil will be available tomorrow, the next day is already in the service.
Oh my teacher, don't get distracted because I got tired of the cost of opel, my car :))
emrah is 2017-06-04 12:52:50
