oil warning
22.07.2021 17:48 # 1
qassim bey
Hi. My car is running out of oil. I knew when I gave a warning. I couldn't go to my master because it was a feast day. I found an open place. said the master at the bottom, let me change the crankcase. He said he was going to install the 307 crankcase anyway, maybe it's true, but I just said let's add oil and then see. I added about 2 more liters of oil. I'll take it to my master on Monday. but the main problem is that oil warning still persists. I checked, it's in oil. what is the problem?
22.07.2021 18:19 # 2
omerb
Get well soon. There may be a problem with the oil pressure switch. Didn't the master who added the oil say something?
I don't think you should ride that way. Just in case. The oil filter etc. is clogged, there is no pressure or something. Watch out.
22.07.2021 19:09 # 3
qassim bey
Is the engine not getting oil even though there is oil in the oil pressure switch?
22.07.2021 19:24 # 4
omerb
The engine may not be getting oil. The oil sensor may not be reading the oil pressure. There are two possibilities. So it's a risky thing.
22.07.2021 19:31 # 5
qassim bey
Sorry, I described it wrong. the warning is: adjust the engine oil level".
I asked the master and he said, "If it doesn't give an oil pressure warning, nothing will happen".
22.07.2021 19:36 # 6
omerb
I sometimes see this warning in my Bnm vehicle. I guess it's normal. You still show it when your way falls. Just in case
22.07.2021 19:43 # 7
qassim bey
yes yes i will show you exactly. one last question. Is it the same with you? so there is oil but does it give a level warning? it could be faulty
22.07.2021 19:56 # 8
omerb
The important thing is the warning given by the oil pressure switch. When I turn on the first ignition, the oil level sometimes says "ok". Sometimes happen. It doesn't read the level. But I see the oil normal on the dipstick. It does not give any oil pressure warning. My friend at Citroen. He said that in older models of Psa, the level sensor sometimes did not measure. He stated that I should heed the oil pressure warning. So there are two warning systems. Oil level and oil pressure. They view the oil level control as unimportant as we manually look at it from the dipstick. But other oil pressure is important.
22.07.2021 19:59 # 9
qassim bey
Thank you very much. Thank you very much. happy holidays.
22.07.2021 20:00 # 10
omerb
Happy holidays to you.
