oil selection
08.05.2020 18:47 # 1
MehmetMehmet
Friends 307 1.6 I had my vehicle lpg 10 thousand km ago.
5-30 oil was added before lpg was installed.
I wonder what oil should I use now. 5-30 or 10-40, etc ... even if you suggest a brand, I would be glad ...
The vehicle is now at 155 thousand km ...
08.05.2020 18:47 # 2
hsnsnl
5-40 or 10-40 totals.
08.05.2020 18:47 # 3
Sercan Mungan
5-40 full synthetic provides the best protection.
08.05.2020 18:47 # 4
yenice
They recommend the choice of oil by kilometer. I had received this information while I was taking the maintenance package. There were 3 maintenance packages.
Filters + Total 10w40 = 130TL
Filters + Total 5w40 = 140TL
Filters + Total 5w30 = 145TL
They said that the price differences here are from oil and they are given by kilometer. I think they suggest 10w40 over 150,000 km or 160,000 km.
08.05.2020 18:47 # 5
206x-line
vehicle 2004 1.4 gasoline brake hydraulic oil brand, do you notice which one is better to put brand and dot series
08.05.2020 18:47 # 6
Sercan Mungan
2006 1.4 gasoline 40 thousand km, my vehicle was between 5w30 and 40, but there is no oil other than 10w40 in the authorized service says fine income.
08.05.2020 18:47 # 7
Sercan Mungan
can be total dot4
08.05.2020 18:47 # 8
ibanez_022
If there is no fat burning in the vehicle, what is the original fabrication is
08.05.2020 18:47 # 9
Sercan Mungan
It seems to be compatible with all according to what it wrote in the vehicle user manual.I think it is fully synthetic 5w40 because it is semi-synthetic oil, but I am afraid of it will damage the vehicle.
08.05.2020 18:47 # 10
suppor
160 thousand 1.4 hdi 206 1 2 months later degistircem 5w 30 mobil 1 esp formula how do you think it would be
08.05.2020 18:47 # 11
suppor
actual
08.05.2020 18:47 # 12
tilbe307
I have been using 5/30 oil for 3 years. If there is an oil leak in his vehicle, he starts to escape more. Because it is oil thinner than 10 40. however, it is said to be better in terms of performance and engine life.
tilbe307 2014-09-12 00:51:29
08.05.2020 18:47 # 13
suppor
[QUOTE = tilbe307] I have been using 5/30 oil for 3 years. If there is an oil leak in his vehicle, he starts to escape more. Because it is oil thinner than 10 40. however, it is said to be better in terms of performance and engine life.
master now 10 thousand km ago I had the maintenance done 10w40 castrol master changed all the filters
I had wiped the oil without running the vehicle that stopped for 1 day in the past, I wiped it again, I would follow it again 4 disten 3u was reduced at the bottom of the oil.
I want to put yag mobil1 5w30 esp formula how do you think
