Oil Selection
08.05.2020 18:30 # 1
iso307
Friends, I'll change the engine and transmission oil. What would you recommend me for both oil? My car 307 1.4 HDI.
08.05.2020 18:30 # 2
KIZILASLAN
In my car, I will change the same as yours 15 days later I think about using castrol edge turbo diesel 4 liters around 110 TL
08.05.2020 18:30 # 3
ahmet_bjk
[QUOTE = dehsetilyo] I will change the same in your car as I am 15 days later I think about using castrol edge turbo diesel 4 liters around 110 TL [/ QUOTE]
yes I also recommend Castrol edge turbo but if you say it is expensive, you can also use Castrol's oil for diesel vehicles. That's 70 lira.
08.05.2020 18:30 # 4
samet2461
total quartz 7000 10W-40 or total quartz 9000 5W-40. These oils are the advice of peugeot
08.05.2020 18:30 # 5
KIZILASLAN
I bought [QUOTE = bitter] castrol edge 5/30 for 95 TL. 110 TL is expensive. Also, whatever viscosity oil has been used in your vehicle, you should continue with the same values.
