Oil Selection |
| 08.05.2020 17:54 | # 1 |
korkusuz202 |
castrol 5/30 and 10/40 Shell & nbsp; & nbsp; 5/30 and 10/40 |
| 08.05.2020 17:54 | # 2 |
generally 5 40 is used 5 30 no need. It is best to write 5-40 people and 5-40 people.
| 08.05.2020 17:54 | # 3 |
1.If you put 5-40 or 10-40 in engine oil in 4 engine vehicles, you will not see a difference, my friend. I have not seen any difference. . I bought a 5w-30 edge.120 TL canister. It was 2000 km. I couldn't see any difference. don't affect the customer ... i think you shouldn't add that much money to the oil. / editID> |
| 08.05.2020 17:54 | # 4 |
[QUOTE = Maverick] 1. If you put 5-40 or 10-40 in the engine oil in 4 engine vehicles, my friend will not see a difference. I have not seen any difference. you can see this difference on a 2.0 TDI or higher engine vehicle. I bought 5w-30 edge. 120 TL drum. It was 2000 km. I couldn't see any difference. performance increased-fuel dropped-working comfortably according to me, I think nonsense ... psychologically influencing the customer ... I think you shouldn't add that much money to the oil. let your vehicle stay without oil .... ![]() |
| 08.05.2020 17:54 | # 5 |
Does anyone know which oil is used to make less noise from the engine?
| 08.05.2020 17:54 | # 6 |
It can be 5w40 Total. |
| 08.05.2020 17:54 | # 7 |
[QUOTE = Turgay_66] Does anyone know which oil is used to make less noise from the engine? [/ QUOTE] my friend says the sound is the tapping for me ... since these are not 16-valve vehicles, they do not adjust the valve automatically after the oil change. My advice to you is that the castrol will take 5w-40 (it is close to 100 TL, no matter where you look), it will change at a distance of 10.000 km. I'll get it. I change oil at 5000 km ... |
| 08.05.2020 17:54 | # 8 |
I read the comments or something, look at the brother, make the valve adjustment, sound was sound, said the master, said the valve, I said this is what the valve is going to pile me up, I used it for 2 weeks. Even though the pressure is lining like a lining, I will make adjustments without changing the oil tomorrow. |
| 08.05.2020 17:54 | # 9 |
My teacher said that the first day I brought the car, the master said that they do it automatically, where are they made, this setting and how much they do, thank you.
| 08.05.2020 17:54 | # 10 |
[QUOTE = Turgay_66] My teacher said the master on the first day I brought the car, they said it was automatic, from where to make this setting and how much they do thank my teacher .. [/ QUOTE] I did not ask for too much, I asked the place randomly, LPG vehicles with 20 thousand Km, Gasoline vehicles 40 thousand 60 Thousand is done, this setting is 80 TL, I do not think the car 2000 model 206 1.4 8 V XR does not make automatic, I do not think that the car would not say it would not do it automatically. I know. The process time is half an hour, but since the weather is hot, the car needs to cool down, it should fall down to 30 degrees at most, so let's start with us. It is expected that the vehicle will cool down, so it takes about 3 hours. |
| 08.05.2020 17:54 | # 11 |
[QUOTE = Turgay_66] My teacher said the master on the first day I brought the car, they said it was automatic, from where to make this setting and how much they do thank my teacher .. [/ QUOTE] it will be automatic if the engine block is the same as in the picture. because these are the 16-valve ones. ![]() if there are other cast engine blocks, they are 8 valves. They do not adjust the valve automatically. ![]() |
| 08.05.2020 17:54 | # 12 |
[QUOTE = maverick] [QUOTE = Turgay_66] My teacher said that on the first day I brought the car, they said it was automatic, thank you. it will be automatic if the engine block is the same as in the picture. because these are the 16-valve ones. ![]() if there are other cast engine blocks, they are 8 valves. They do not adjust the valve automatically. ![]() |
| 08.05.2020 17:54 | # 13 |
[QUOTE = Turgay_66] [QUOTE = maverick] [QUOTE = Turgay_66] My teacher said the master on the first day I brought the car, they said it was automatic, thank you. [/ QUOTE] it will be automatic if the engine block is the same as in the picture. because these are the 16-valve ones. ![]() if there are other cast engine blocks, they are 8 valves. They do not adjust the valve automatically. ![]() is not a job that has difficulties. In total, it will use two tools ... ratchet wrench and ratchet wrench ... I made 50 TL for my 206 sold last year. |
| 08.05.2020 17:54 | # 14 |
I will go to an industry tomorrow, thank you very much, teacher :)
