Oil Recommendation
08.05.2020 20:04 # 1
Selox
Hello guys;
206 1.4 HDI x-line 2003 suggests a total of 10-40, but how about we get castrol or something, isn't it? What is your suggestion ? I will change tomorrow today.
08.05.2020 20:04 # 2
I use mobile 5w / 40. You can choose either castrol and mobile either.
08.05.2020 20:04 # 3
Selox
Eywa. I was thinking castrol, thanks for the information :)
08.05.2020 20:04 # 4
dejawu1978
Choose the oil according to how many kilometers the vehicle is and how the engine condition, oil reduction, etc. is similar.
08.05.2020 20:04 # 5
Selox
-10; It passes in the -25s, usually in winter. Yozgat. There are no 208 000 deductions. Healthy engine performance is good. what do you think? Selox 2016-12-14 13:01:59
08.05.2020 20:04 # 6
dejawu1978
you can look at the link below
http://poas.lubricantadvisor.com/default.aspx?lang=t is
5/40 castrol makes sense ...
08.05.2020 20:04 # 7
Selox
I get it, brother. my opinion was canstrol 10/40. I think you understand this. What is the difference between 5/40 and 10/40? Why didn't you recommend 10/40? Isn't it 10/40 more protective?
08.05.2020 20:04 # 8
eng uzn
Hi friends. I am new to you. 2001 model automatic 206 there is in me 195 thousand which oil do you think I should use
08.05.2020 20:04 # 9
It is 10w / 40 semi-synthetic and thick oil. 5w / 40 is fully synthetic and thinner than 10w / 40.In winter, the vehicle heats up faster in winter, engine lubrication becomes faster than 10w / 40. 10w / 40 -35 freezes, 5w / 40 freezes at -50 etc. I said the degrees as an example, it is almost around that. You have to change 10w / 40 10 thousand km. It has a maintenance range of 5w / 40 and 15 thousand km. Of course, it is good in terms of engine health of the vehicle that you change it 1-2 thousand km before the vehicles used in continuous traffic depending on the usage. When you put 5w / 40, there may be a little reduction in oil because it is thinner.
08.05.2020 20:04 # 10
[QUOTE = eng uzn] Hi friends. I am new to you. 2001 model has 206 automatic me in 195 thousand which oil do you think I should use [/ QUOTE]
10w / 40 will be sufficient for istanbul. because there are not too cold temperatures and the vehicle is gasoline.
08.05.2020 20:04 # 11
hzr206
I put a total of 10w 40 oil.
08.05.2020 20:04 # 12
eng uzn
Thank you for your interest and concern
08.05.2020 20:04 # 13
EMRE_R19
Elf Moligraf F1 I only pass this oil!
08.05.2020 20:04 # 14
Sercan Mungan
Mobil 1 0w40 new life is my only one try, you will not be able to give up. Also, my vehicle did not reduce up to 10 thousand kilometers of oil.
08.05.2020 20:04 # 15
Selox
[QUOTE = EMRE_R19] Elf Moligraf F1 I only pass this oil! [/ QUOTE]
I know elf tests are so bad. It's like 90 degrees of water at 100 degrees. But it does not lose its total castrol feature and remains semi-fluid. I think one more time.
08.05.2020 20:04 # 16
Selox
[QUOTE = sonerkyl] 10w / 40 is semi-synthetic and a thick oil. 5w / 40 is fully synthetic and thinner than 10w / 40.In winter, the vehicle heats up faster in winter, engine lubrication becomes faster than 10w / 40. 10w / 40 -35 freezes, 5w / 40 freezes at -50 etc. I said the degrees as an example, it is almost around that. You have to change 10w / 40 10 thousand km. It has a maintenance range of 5w / 40 and 15 thousand km. Of course, it is good in terms of engine health of the vehicle that you change it 1-2 thousand km before the vehicles used in continuous traffic depending on the usage. When you put 5w / 40, there may be a little reduction in oil because it is thinner. [/ QUOTE]
Eyw brother. I bought Total 5w40 9000 quartz in terms of its original. Information.
08.05.2020 20:04 # 17
M&K
My vehicle is 206+ diesel. This summer, Mobil 1 ESP Formula 5W-30 was launched. By Bostanci Harun Usta. He said it will change after 15,000 km. I don't know much about this. 2.000 km of oil remained to change. I wanted to ask when the ready topic was opened. Do you have friends using it? Is this suitable oil?
08.05.2020 20:04 # 18
Selox
[QUOTE = M & K] My vehicle is 206+ diesel. This summer, Mobil 1 ESP Formula 5W-30 was launched. By Bostanci Harun Usta. He said it will change after 15,000 km. I don't know much about this. 2.000 km of oil remained to change. I wanted to ask when the ready topic was opened. Do you have friends using it? Is this suitable oil?
The 100 degree test I was talking about passed through this product. He did not lose his characteristic. My soner also uses it. Suitable.
Selox 2016-12-15 15:38:35
08.05.2020 20:04 # 19
Do not be too stuck with the originality in oil, but do not change too much oil brand. 5w-30 mobile 1 esp is suitable in your vehicle.
08.05.2020 20:04 # 20
M&K
Thank you. So should this oil change 10,000 km or 15,000?
Page : / 2
