oil problem
15.08.2022 23:26 # 1
DK14
Hello everyone, I bought a new 206 ( 2004 desire ) ( km 134 thousand ) (automatic transmission) and spent 25 thousand and made it like a flower inside and out, but I have a problem, the last time a master said, I am a 40-year-old master, I have never seen anything like this
< br>
The car does not emit black, white or blue smoke, there is no oil leakage, the spark plugs do not burn clean oil
But the oil is getting low, about 2 liters of oil is lost in 1000 km
I had castrol oil poured first, and it came off, then I had castrol 10.40 oil added from the original dealer.
What is the solution for this one help
18.08.2022 23:26 # 2
talip206
If the gasket was burned in the vehicle before, the cover was revised and the underside (block) was not checked or it was ignored due to cost, the vehicle may reduce oil without any indication (without smoke, etc.). It is easy for the masters to not understand at first glance.
The second situation is that if there is a problem with the oil steam hose, etc. on the rocker cover, the evaporated oil may be thrown away without being reintroduced into the system.
