Oil Pressure Warning (When Turning Steering)
08.05.2020 21:15 # 1
Silici13
First of all, Hi, Aleyküm Peugeot 307 Var Yag Pressure Warning Gives Low Error Continuous Alone Steering Half. Turns This Warning In The Translation Of The Tour Beeps Beep Information Does anyone know what is?
08.05.2020 21:15 # 2
grkncck
Hello there. Turning the steering wheel should increase the speed. If it is falling, the engine may give temporary oil pressure warning. It is not normal, you have to look. If the oil has been changed recently, it may be caused that the oil filter is not properly installed. Fitting the protrusion of the filter into its place in the engine solves the problem. No need to change oil again, you can just replace the filter. Get well soon.
08.05.2020 21:15 # 3
Silici13
First of all, thank you. I would show the show that sometimes the Direction is going on before it, but he said to the master, but the problem would be from the matter (Yag).
But it still hasn't improved. When the Attachment Attached to the Machine, the Oil Sensor was giving the warning but the problem is in the following vehicle.
08.05.2020 21:15 # 4
grkncck
It's a very frustrating situation. My vehicle is diesel. Idling speed is between 800-850 rpm. It keeps the revs high when you dispose of it while the vehicle is moving. No problem. However, when it drops below 800rpm when you stop, it gives oil pressure warning. I changed the filter, it did not improve at first, but it improved when it threatened to use a little cycle and sell it.
08.05.2020 21:15 # 5
Silici13
I talked to the master, he told me he could be from Filter or SüGeç.
