oil pressure warning
08.05.2020 19:49 # 1
selba
Hello to everyone
friends my first message to this forum. 2007 model 307 hdi comfort vehicle.I am very pleased with my car. there is only one problem. I think the oil is giving a pressure warning. It is singing twice. Could this be an important problem or a malfunction failure. Thank you.
08.05.2020 19:49 # 2
Mrttt53
I had an incident like the oil pressure is low, and my left brake hose was torn whatever it was. It started to move and not hold the pressure to 2 3 brakes. It may be useful that you are warning the brake hydraulic pressure.
pression d`huile insuffisante = oil pressure insufficient
08.05.2020 19:49 # 3
rapsodi_in_blue
Hello there,
Did you find the source of the problem? The same problem started in my vehicle.
08.05.2020 19:49 # 4
[QUOTE = rapsodi_in_blu] Hi,
If your oil filter is not original or the production is wrong, it may give this problem.
08.05.2020 19:49 # 5
rapsodi_in_blue
but only on the hard turns that I turn the steering wheel to the right. No oil in the vehicle. We couldn't find the problem
08.05.2020 19:49 # 6
If he turns the steering wheel, he may have a chassis somewhere. this is a possibility that can give an error like this. the best method is to remove the oil pan of my teacher, make it clean and make it with the original oil filter.
