"Oil Pressure Too Low" Error On 307
08.05.2020 16:02 # 1
kuantum
I changed the engine oil somewhere 2 days ago. But when I got into the car first this morning, and then tonight, I got the error "Oil Pressure Too Low". I went and bought 1 liter of oil and added to it. Then I started my car again. Again it has not improved. I called the Pejo 7x24 service. Because I was in Taksim in the blind of the night. The service officer said that if the oil fault light is not on, there is no problem. So I started off with her. By the way, where I parked, I looked under the vehicle. There was a slight oil leak. However, I had no such problem. I wonder if they couldn't put the cover on the bottom well after the oil change, but the oil decreased in two days?
I will see if my car is in front of the house, will give the same error again tomorrow morning.
08.05.2020 16:02 # 2
When you look at the oil, if the oil is decreasing, there is a leak from one place that they probably could not tighten the sump plug. Do not use your vehicle with missing oil.
08.05.2020 16:02 # 3
kuantum
they probably couldn't fully tighten the plug. These guys will make you crazy. they were so indifferent that evening.
08.05.2020 16:02 # 4
[QUOTE = quantum] were probably not able to fully tighten the plug. These guys will make you crazy. they were so indifferent that evening. [/ QUOTE]
After starting the car in the morning, move it a little and check if there is oil on the ground where ten people come. If it does, it can also be removed from the plug or somehow filter. The result is a leg.
08.05.2020 16:02 # 5
taksicicocuk
Brother, they open the plug from the bottom, it will not hold that plug again. if the engine is left without oil, the pistons will wrap the car then the car kits itself and the huge expense :(
I think look at me
08.05.2020 16:02 # 6
Mehach
It may be because the oil is added too much. It got better when I decreased.
08.05.2020 16:02 # 7
[QUOTE = taksicicocuk] my brother does not hold the plug again when they open the plug from the bottom that it is necessary to thread again for the plug, probably they did not. if the engine is left without oil, the pistons will wrap the car then the car kits itself and the huge expense :(
I think look at me
The plug is not changed, the gasket is changed if it is, it is changed at 3-4 oil change if it leaks. Are you talking about a different thing? Shocked
08.05.2020 16:02 # 8
kuantum
I just looked again. The vehicle did not drain oil but it still gives the same error. I checked the oil level, oil is not missing. Then why can he do that? Someone said something like "the oil pump or the sender may be broken." Can something like that happen?
08.05.2020 16:02 # 9
hamham
my friend the same thing happened to me and you checked how many numbers of oil was made because the authorized service put oil at different number
08.05.2020 16:02 # 10
kuantum
5 40 I guess what they put? in this case, pour this oil and make zero another vehicle ???
I wonder which oil is suitable for this vehicle? 2006 model new chassis 1.6 gasoline triptonic ??
08.05.2020 16:02 # 11
Erman41
I do not know if your problem is solved, but I am using 206. There was something like this, the oil lamp was on, some were said, some said, the pump said, the problem came out of the filter. There is no problem.)
08.05.2020 16:02 # 12
kuantum
I guess the problem was the filter. And the place where they pour the oil down was licking. 2-3 days, the vehicle drained oil from there. Fat is missing. We renewed the filter and had it repaired, thank goodness ... I do not think I will go to that master again.
08.05.2020 16:02 # 13
SZKR
I think look at me
[/ QUOTE] It is the first time I hear the thread being opened again. I think this was a misinformation, because in oil changes, the oil is taken from this plug. An application like releasing guides at every oil change is risky and impossible. Even if you grow your teeth every time and adjust the plug accordingly, metal shavings in the sump can cause disastrous damages.
08.05.2020 16:02 # 14
ByHack
Replace the filter when friends change oil, it is not a very costly part anyway. Also replace the gasket on the cartel, even wrap the gasket with Teflon tape so that your job is guaranteed. By the way, isn't the ideal oil 10-40 normally used?
08.05.2020 16:02 # 15
[QUOTE = ByHack] Friends change the filter when you change oil, it is not a costly part. Also replace the gasket on the cartel, even wrap the gasket with Teflon tape so that your job is guaranteed. By the way, isn't the ideal oil that should normally be used 10-40? [/ QUOTE]
Here you have to define the ideal. What is the ideal? Which vehicle type, which climate, which engine, which fuel tour ... etc?
08.05.2020 16:02 # 16
metin
which car is the ideal oil for which engine?
If you specify your car in our signature, we are using this tool according to it, so let's comment on this engine, this engine, this fuel, this oil is put into this engine, etc.
Please fill the information in your profile completely, and write your vehicle's brand model, fuel type engine volume equipment, etc. in the signature section.
08.05.2020 16:02 # 17
metin
[QUOTE = quantum] 5 40 I guess what they put? in this case, pour this oil and make zero another vehicle ???
they put me 0-40w in the service, I am very glad, there is no decrease etc. vehicle 2004 model old body 307 1.6 110 hp automatic.
08.05.2020 16:02 # 18
eXistenZ
Hello Friends, I would have a question for you, I have 1.6 diesel pejom last year before my leave was left, my car remained on the road, the oil pressure made a mistake, then he changed the muller, the error went, but this year I made a mistake, he made the same mistake again, he went to the same mechanic, he said, he made another mistake, he said, he made another mistake. said the price did not seem convincing ... I will change the oil filter again, I searched this recently, they said that the oil selection is important, the most suitable oil for this engine is 5w / 30. I'll try ins. helps. Do you have any other ideas on this subject? If you share it, I would be very happy.
Best regards
08.05.2020 16:02 # 19
gurkannn
It happened to me in the last oil change. My vehicle is 2008 model 308 comfort 1.6 HDI 90. Especially when the engine warmed up, it was warning that the idle was reduced to 750 rpm. Problem solved. My advice on this subject
1. Do not load on the engine while the engine is idling. It can cause serious trouble.
2.No need to change the oil again, just replace the filter.
3.If the problem is not solved, you will go as a pump.
Filter replacement is different in our vehicles, the filter is placed first, then the cover is attached. Do not attach the filter to the cover and install it. This is really important. After filter replacement, the error may not pass immediately, make some performance 40-50km road. Getting used to it, the filter may be delayed a bit. I also threatened the car, I will sell you. It may have been so: D
It was caused by the wrong installation of my filter. I hope it helps.
I use 5w30 full synthetic, I had no problems. Use top quality oil, especially for turbo health. My vehicle is at 200.000km.
08.05.2020 16:02 # 20
Selcuk55
I always say, do not leave your vehicle, definitely install the original oil filter, there are vehicles that eat engine because of the sub-industry filter. Wink
Page : / 2
