OIL PRESSURE LOW and Engine Stops !!!
08.05.2020 14:15 # 1
controller
Hello everyone, everyone ...
It has been 2-3 months since I took my 2006 (307 gasoline trip.) Model car. I said whatever I took to the service, the timing set changed, the minor deficiencies were eliminated and I started using it smoothly ...
I only have a problem like this, while the car is driving on the road, the engine stops without stopping, so it stays :) I did this once before the service, I did it later, my brother did it, the last time he did it for the third time and now it starts to bother me ...
After the engine stops, the starter does not operate without touching the throttle again, the engine stops when I take my foot off the gas (as if there was an idling problem). Just like the engine stops, I try to do this for 10 minutes or so, but the same thing continues. Before you stop the car at 1000-1500 revolutions (Drive), it goes away when you put it in gear, but if you wait for it to stop and stop it, it says "OIL PRESSURE LOW" and the engine stops again.
By the way, the vehicle has LPG BRC brand ....
What do you think I have to do, do I have a friend like this happening ???
08.05.2020 14:15 # 2
trtolgi
I think the problem is lpg de. You should have a good master at your settings.
08.05.2020 14:15 # 3
hasimayaz
it may not be able to press enough oil because it cannot hold the cycle. First fix the vehicle idling problem, it may be related to lpg. it is necessary to follow the oil pressure problem later.
08.05.2020 14:15 # 4
controller
[QUOTE = hasimayaz]
When I say LPG problem? He does the same with gas. It was futile if I bought it in gasoline after the new engine stopped: S just called my brother today the same thing he did ...
08.05.2020 14:15 # 5
controller
So I'm going to drive the car tomorrow, but in which order should I start the service-master and the LPG ci planet?
Do you think LPG ci, master, service is appropriate ???
08.05.2020 14:15 # 6
fireblade
I think first connect a computer to the car ..
If he has made a mistake, you will see him. If there is nothing, you will go to lpg.
08.05.2020 14:15 # 7
controller
I cleaned the throttle, replaced the air filter and spark plugs, the problem disappeared. 80 tl stuck throttle :))
