OIL PRESSURE LOW
08.05.2020 16:56 # 1
joel_55
Hello, I just joined the friends forum. I WANT TO SHARE YOUR BI LINE ASIYAA WITH YOU TO GET INFORMATION. 307 1.4 I HAVE A GASOLINE VEHICLE. TODAY AKSAM UÇARI YÜ PRESSURE GAVE LOW ERROR. WHAT IS THE PROBLEM?
08.05.2020 16:56 # 2
Have you checked the engine oil level of your vehicle from the cube?
We have an introduction form for newcomers. We will be very happy if you can fill it.
Link: For new friends joining us.
Thank you.
koliva 2012-07-29 00:29:43
08.05.2020 16:56 # 3
joel_55
yes I checked the bar looks normal there is no deficiency. Valves and spark plugs have changed since I thought I had already removed it. in the evening started to give this error
08.05.2020 16:56 # 4
[QUOTE = joel_55] yes I checked the bar looks normal there is no deficiency. Valves and spark plugs have changed since I thought I had already removed it. evening started to give this error [/ QUOTE]
Why are the valves replaced?
08.05.2020 16:56 # 5
istanbullu_3886
The valve needs to be removed for the valves to change.
08.05.2020 16:56 # 6
joel_55
yes, the roller cover was inserted. The malfunction lamp was on, I took it to the industry, the valves were burned, they changed and some more. When the problem is solved, when the oil pressure is low, it gives signal.
08.05.2020 16:56 # 7
istanbullu_3886
I think it was like why interesting valves burned and the breakdown of heat failure was interesting!
08.05.2020 16:56 # 8
If I were at your place, I would have brought back the change masters without using the tool any more. Reviews
08.05.2020 16:56 # 9
joel_55
I will do it like Monday, no problem is seen anymore, according to the error it normally gives, but the thought of the transfer gives the error & nbsp;
08.05.2020 16:56 # 10
[QUOTE = joel_55] I will do it on Monday, no problem is seen anymore. [/ QUOTE]
You should take this error seriously. The problem may not seem to be right now because the problem takes care of the right time and place.
Was there an oil change in your vehicle?
08.05.2020 16:56 # 11
istanbullu_3886
Is there a different gag in the vehicle & nbsp;
08.05.2020 16:56 # 12
istanbullu_3886
it seems to me as though the triger's sentence is worn, but & nbsp;
08.05.2020 16:56 # 13
joel_55
I had an oil change, but it will be about 4-5 months ago. There is no different thing or slap right now. I did not control the tribe I do not know if it can be from him tomorrow at least let me check it myself
08.05.2020 16:56 # 14
istanbullu_3886
you can not control it by yourself. There are 3 or 4 pulley teeth in the belt. It must be balanced.
08.05.2020 16:56 # 15
istanbullu_3886
I'm not sure I want to inform you wrong, sorry!
08.05.2020 16:56 # 16
istanbullu_3886
Sorry, but why did the sticks not make the burned vehicle full lubrication or overheat?
08.05.2020 16:56 # 17
istanbullu_3886
I think it is probably due to lubrication, if it is burnt due to lubrication, the oil pump is not fully lubricating or there may be a blockage in the oil ducts & nbsp;
08.05.2020 16:56 # 18
joel_55
Combustion caused by oil. According to this situation, as you call it, it gives a seat from the error in the oil pump or oil channels.
08.05.2020 16:56 # 19
istanbullu_3886
I did not connect the master to the computer before the operation
08.05.2020 16:56 # 20
joel_55
If you think the oil pressure is low error, no, because it started to do this tonight. yes for the error in the valves. it says there is burning, but it does not say exactly where it is. The master said at first that the spark plug bobbins were burned, but the error continued, and then I thought I thought there were valves too, and he changed the error.
Page : / 2
