oil pressure insufficient. error message .. Emergency yard
08.05.2020 19:32 # 1
nejadeth
Hello.
Isn't there any friend who can solve this problem known as low oil pressure?
The subject has been repeated many times. But there is no conclusion.
I changed everything until the oil pump.
I paid 2000 TL. The result is the same ..
I do not understand what kind of disease. He cooled me out of my vehicle.
Your Help. Thanks for.
08.05.2020 19:32 # 2
cengo
I guess there is the same problem with me, but no one can find a solution
08.05.2020 19:32 # 3
KILIC
would you give some information about the vehicle.
08.05.2020 19:32 # 4
sdttn
If you are sure that there are no mechanical problems, electrical wiring, sensor and brain should be checked.
Is a manometer connected and measured on the road?
sdttn 2017-04-06 17:47:32
08.05.2020 19:32 # 5
cengo
When the engine of the vehicle warms up, when I do not gas, the bass gives the oil pressure warning when it is idle.
08.05.2020 19:32 # 6
sdttn
It looks like a blockage or alternator / electrical failure.
In diesel, vacuum pump oil inlet and oil cooler (oil exchanger) can be clogged.
sdttn 2017-04-08 18:27:33
