oil pressure insufficient. error message
08.05.2020 19:16 # 1
nejadeth
Hello there.
This problem was not mentioned in many places in the forum.
oil pressure insufficient. Gives low oil pressure warning.
It gives this line especially in the city. It gives oil lamp and stop warning.
He said, let's change the master filter and oil manager. We did but still the same problem continues. The oil pump is probably right now, he says.
If I knew this was the exact problem, I might not change it.
Is there any friend with knowledge or experience on this subject?
are there.
thanks.
08.05.2020 19:16 # 2
berk2309
If the oil filter of the teacher has changed originally, the oil pump is already in the back, but I hope it is something smaller.
08.05.2020 19:16 # 3
simirnoffredbull
Dude, do you want the oil in the car? He usually does this because he puts 5/30 oil on the pejo (gasoline). If it's 5/30, change it to 10/40 oil. Since the oil is thin, it cannot be thinned and applied the required pressure when the engine is heated.
08.05.2020 19:16 # 4
nejadeth
Dude I checked him too. 10.40 oil was used.
I changed it 3 months ago. It was 2000 km.
I wonder if I change the oil again.
Without understanding what the exact problem is,
changing does not come true. I think it would cost 1000 TL
08.05.2020 19:16 # 5
nejadeth
Oil level max. Looks 1 ~ 1.5 cm more than its level. Could this be bored?
08.05.2020 19:16 # 6
nejadeth
friends
Problem solved. Although I do not ask for special service, the supplier industry has put a filter. It turned out when he changed it to another master. A brand called fil filter. Sales price 4.08 tl ..
Bosu would replace the oil pump to the empty pump.
My advice to the friends who will face this problem from now on is to make sure that the oil filter is original.
Thanks.
