Oil pressure
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
08.05.2020 20:50 # 1
Cihan 33
Mrblar partner tepee car oil cooler exploded, we changed the master oil cooler oil antifreezes oil and air filter also my car did not work, did not do the temperature, but after a few days the warning "stop breakdown oil pressure" appeared on the display screen, but when I run the car in the morning, it gives the error, then it shows the error, then it does not appear on the screen. I showed you to your service again, he changed his oil filters, opened the oil pan, washed the oil sensor, he changed the oil pump strainer. He said, I haven't shown it, please, if you help me, I'll be very happy if you let me know. so does 2013 model 92 hp 90 km
Cihan 33 2018-04-13 11:11:44
08.05.2020 20:50 # 2
pusutr
Is there a problem with the oil pump?
08.05.2020 20:50 # 3
First of all, welcome to us. Sir, if there is no error code when you connect a pc and the car does not give any sound warning, it is not a problem if it goes out immediately after starting the starter at the first start. And when you turn on the ignition, what lights remain on the display screen and the oil level light is also on. If it is on, it is possible that the oil level sensor may be faulty.
08.05.2020 20:50 # 4
boruc
Have you connected to the computer and deleted the error codes? Old errors may be recorded in the brain memory and be warning
08.05.2020 20:50 # 5
Cihan 33
Thanks for your comment, first of all, I suspect the oil pump in the industry, but if there was an oil pump, the oil lamp would be on all the time, but it does not go on. It does not light up.
08.05.2020 20:50 # 6
Cihan 33
Thank you very much for your interest, we liked it, admin did not connect the vehicle to the pc when I turn the contact, the oil does not remain official on the screen, it only gives the error in my first run, then it goes out, even without giving gas, the stop oil painting comes out and goes off immediately after the first starter.
08.05.2020 20:50 # 7
Cihan 33
My teacher, I did not connect to PC, I will go to the industry and connect and then write cvp tskler for your attention
08.05.2020 20:50 # 8
pusutr
When our vehicles are already turning the ignition, all the warning lights come on for control purposes and go off after the engine has started. I guess that's yours. So there seems to be no problem with that. Or shoot a video and let's examine together.
08.05.2020 20:50 # 9
Cihan 33
I have connected it to my PC PC, there is no error code in the industry, there is only one in the engine and there is a license plate lamp error. Take it to the service in the industry.
06.10.2020 12:18 # 10
Hasan.g27
I have the same problem now, how did you solve it
06.10.2020 12:20 # 11
Hasan.g27
I have the same problem, how did you solve it
27.11.2020 05:13 # 12
Berkozturk
[QUOTE = Hasan.g27] I have the same problem, how did you solve it [/ QUOTE] I can suggest that you go from cost-effective to high on alternatives. When you connect it to the computer, a solution can be produced depending on the error code it has failed. First, check the oil level, oil sensor and oil cooler mechanically and physically. Depending on the result you find, clear the error codes and if it repeats you can head towards the oil pump, but until the job goes to that part, the vehicle will try to make its voice with many different problems. If there is any incompleteness or mistake in the steps, it will correct me.
30.08.2021 11:36 # 13
eyayy
Good forums. The "low engine oil pressure" fault explained above is also present in my new 2016 model 308 vehicle. I get this error every morning when I start the engine, especially when the engine is cold, then it goes away. The person I bought it from said that he changed the oil cooler of the vehicle and he did it 1-2 times while using it himself. In other words, this malfunction occurred when the oil cooler was changed. The oil pump, oil switch, oil filter and oil cooler of the vehicle, which is now being repaired, have been changed. However, the same error still exists. We cannot find a solution. I'd appreciate it if anyone found a solution.
30.08.2021 11:37 # 14
eyayy
I have the same error. Were you able to find a solution?
