Oil pressure
08.05.2020 20:32 # 1
fragman
Happy holidays to everyone
308 2012 model vti 1.6 petrol 45 thousand km lpg you car
It gives the message of check the oil level to the starter pressure for the last 1 week, but only the message appears on the first starter, then it does not give any warning while driving. The oil lamp does not light up. it was 5 thousand km of service, the service total guartz put 5 - 30 oil 15 thousand km, said come, so there are more to the oil change
Let me add 1 liter of oil but this time it will be too much oil because it is full
Since someone knows, come
08.05.2020 20:32 # 2
ggitaristt
If the bars showing the oil level when the sister opens the contact, all of them are full, the oil sender may be broken or the socket is not in contact. Add oil until the oil is max. Don't worry.
08.05.2020 20:32 # 3
fragman
Isn't there anyone who knows?
08.05.2020 20:32 # 4
I don't have a teacher, probably the sensor is faulty. Check from the dipstick if there is no reduction. If there is another fault record, or you will replace it in the next maintenance. It's not an expensive piece anyway, 30-40 TL oil sensor
08.05.2020 20:32 # 5
fragman
Greetings, as I said before, the oil level seems normal in normal oil, but today a friend has lost the oil feature, change it, it says it will recover, sometimes it says that the oil has been put in the past, the visokete feature has disappeared or the sensor thinks that there is no oil pressure pump because it could not press the oil.
08.05.2020 20:32 # 6
Yes, if it is a very old oil, the oil pump may not be in the required pressure, but in this case, the engine turns on the stop light and the vehicle protects itself. I think you can buy the disabled oil yourself with the quality oil like mobile esp formula 5w / 30 or motul x8100 fe and make it change. Also, in rare cases, the oil filter can also cause such problems. My advice is to get my oil-oil filter and oil customer by yourself, I can even remove the oil cartel and clean it well. The oil pump is not a piece that will easily break down
