Oil next to the Turbo - (Result) |
| 08.05.2020 18:01 | # 1 |
| 08.05.2020 18:01 | # 2 |
I do not know what is called the master, who is seeing the oil there and is 5 minutes away from the gasket change. I recommend you to fix the leak there as soon as possible. contributes to low traction.
| 08.05.2020 18:01 | # 3 |
Do you think it is from the gasket?
| 08.05.2020 18:01 | # 4 |
First, it changed the gasket of the turbo. The pressure generated by the turbo goes to the intercool that way. there is probably an air escape from there, so it will affect the traction. but first it goes to the problem there.
| 08.05.2020 18:01 | # 5 |
All three masters said something simple. I shared it for you to learn, at the same time, for non-living friends. Thanks qqyyxx.
| 08.05.2020 18:01 | # 6 |
It's not important, then why should you pay attention to the oil? Oh, these masters are there. Any oil leaking oil leaking is important to me.
| 08.05.2020 18:01 | # 7 |
Serkan is the one who can not get high money for hand labor.
| 08.05.2020 18:01 | # 8 |
gogly35 |
Even though it was past, we had our diesel focus vehicle, it affects the performance and traction of a small leak in the turbo hose. It is the best solution to change.
| 08.05.2020 18:01 | # 9 |
gokhn89 |
Well, brother, I just took a photo, I was going to open the subject, you behaved before me, even though it is not as much as you, there is oil in the same place.
| 08.05.2020 18:01 | # 10 |
IF I HAVE LOW OIL LEAKS ON THE SAME PLACE, I HAVE ALSO HOWEVER I RECEIVED THAT OIL IS IMPORTANT.
| 08.05.2020 18:01 | # 11 |
Well, my brother came to print in my new ones. I check often because I don't have white smoke, but your situation may be something forward. There are friends who can help if you throw a picture. But you better go straight to a master.
| 08.05.2020 18:01 | # 12 |
If it is too heavy, it removes excess oil. Let the oil level just below the top line on the stick.
| 08.05.2020 18:01 | # 13 |
gokhn89 |
Well, I checked it in the morning, I think it's a little bit more than my last line.
| 08.05.2020 18:01 | # 14 |
It is not a good sign if the oil flows from any point of the engine. It is best to take preliminary precautions for them, as their little fat will cause serious problems in the future. In addition, when you put too much oil on the sump, there is no incident that it will throw away more. It exits by damaging the weakest part, which is abnormal. The oil leak in the engine is like bleeding in man. It is useful to take measures as soon as possible. I exaggerated a little, but it is important for the engine's life. |
| 08.05.2020 18:01 | # 15 |
Hodja, do you know how to insert that piece .. I know that the gasket is not sold one by one.
| 08.05.2020 18:01 | # 16 |
I saw the oil in the bonnet early in the morning, I saw that the place I marked was coming from the left-hand screw. I don't know if it comes from somewhere else, but it was a bit good. I don't know, guys, I'm going crazy. I love my car so much but I get mad when I see such things. Though I know the lion will not leave it on the road, unless it creates electronic trouble :)
| 08.05.2020 18:01 | # 17 |
Gentlemen oring is dead where I pointed it out, I got it done. We put the oil fully synthetic, we replaced the oil filter, the diesel filter was clean, we left it, I replaced the air filter in 500 km. As if the vehicle is still low. I don't know, is it psychological?
