oil level (oil ok) error (oil -)
08.05.2020 17:02 # 1
kuantum
Every time I start my car, it says "OIL OK" and then returns to KM where there is trip. But when I started my car yesterday evening, it always wrote OIL - where it says OIL OK and it starts blinking. I immediately got out and measured the oil level of the cold engine. It turned out low. This morning I went, the master said we need to add 1 lt of oil. We've added. But when I started the car it gave the same warning. Since I was about to be late for work, I was not tampered with. But my mind is now there. Why do I still see the text "OIL -" despite adding oil?
Meanwhile, the vehicle has 10,000 km maintenance and 2,000 km oil change.
08.05.2020 17:02 # 2
berk2309
Don't trust him too much, my teacher, the oil level is full in the oil level, the manager is defective or if the vehicle is not flat, I cannot measure from it.
08.05.2020 17:02 # 3
oozcan42
Peugeot do not rely on this electronics. Trust what the dipstick says.
08.05.2020 17:02 # 4
HLTYLMZ
oil amount max. when it is over, it gives the warning. Sometimes I was getting a similar warning in my C2.
08.05.2020 17:02 # 5
metin
do not rely too much on the oil sensor. sometimes he can say that there is a problem. Even if you change the sensor, you may encounter the same problems as the part is problematic. & nbsp;
The best thing is to open the hood and check it by looking at the oil stick. & nbsp;
08.05.2020 17:02 # 6
Efe-Pojo
I also changed the oil, the master put more oil, oil - wrote, how we can fix this situation.
25.09.2023 14:19 # 7
mercanovic
Hello. Has anyone found a solution to this problem? I experienced the same thing, and I'd appreciate any help. The oil level is normal. Physically checking it doesn't show any issues. Also, is this problem only with engine oil, or does it trigger this warning with other oils? Thanks. mercanovic2023-09-25 14:21:21
